1937 Ford twin Turbo LSX
Old 12-28-2010, 10:23 PM
Eddie2011's Avatar
Default 1937 Ford twin Turbo LSX
So here are some pics of my personal project. It is a little slow going since I don't get a lot of time to work on it.
1937 Ford coupe
LSX tall deck with LSX DR heads (planned) ls1 in for mock up
twin 88mm Comp Turbos
gt40 transaxle
c5 corvette suspension
Tube chassis
Chopped 5 1/2"
Sectioned aprox 6"
Widened 6" @ rear
Thats pretty much the guts of it.
Old 12-28-2010, 10:28 PM
Eddie2011's Avatar
The chop was easy to decide on, but it took a little playing to figure out the section.
I have a lot of bars to add still, but the basic structure is there, enough to start putting in the major pcs so I can figure out how much room I don't have to work with.
Old 12-28-2010, 10:33 PM
Eddie2011's Avatar
Firewall
Old 12-28-2010, 11:21 PM
Stormed_Norm's Avatar
Wow. Talk about thinking outside the box. Very nice work.
Old 12-29-2010, 11:03 AM
Crystalss's Avatar
Wow...love this kind of build! Great idea and creativity!
Old 12-29-2010, 11:26 AM
Fahrenschnell's Avatar
That is awesome!
Old 12-29-2010, 11:32 AM
80superbu's Avatar
Looks like a fun project. Will there be something blocking off the engine? I foresee a LOT of heat from the motor. Guessing the turbos will be up front under the hood?
Old 12-29-2010, 09:18 PM
Tig
Tig's Avatar
THATS insane. You do some incredible metal work.
Looking forward to this build.
Subd
Old 12-29-2010, 09:24 PM
eviltwin_1987's Avatar
thats like 2500+hp worth of turbo right there. how much do you plan on making? C.I.?
Old 12-29-2010, 09:52 PM
Eddie2011's Avatar
Yes there will be a rear firewall. It will have to be in several pcs so it can be removable for access. There will be an x in the cage/frame going in front of the motor from the seat belt cross bar down to the bottom frame/main hoop intersection. The panels are going to be a sandwich construction with plenty of dynomat and other insulation in between. The car is going to be a street driven car and is getting heat and air so I want to make it comfortable.
The turbos are going all the way in the rear and will sit on top of the transaxle directly behind the motor. Will be a nice show pc with the trunk open.
Old 12-29-2010, 09:58 PM
Eddie2011's Avatar
Its still in the planning stage. Hopefully will have the turbo's ordered in the next week or two. I am getting some help form friends with expertise with these settups so I have not really finalized numbers yet, but some where in the 427 ci range and 1800-2000 hp being the goal. The turbo's may get downsized to 82mm after a few discussions we've had lately. I am more concerned with overall driveability/spooling than max hp so we'll see.
I would like the car to be able to run Texas mile/ Bonneville and Siverstate classic, so its alot to ask of one car. Won't be the best at any of them but it will be fun to have a real baddass all around car.
Old 12-29-2010, 10:01 PM
overhere's Avatar
you do some very nice work! cant wait to see more progress.
Old 12-30-2010, 07:28 AM
98SuperchargedLs1's Avatar
man thats a cool project.. cant wait to see more pics
Old 12-30-2010, 07:36 AM
black06g85's Avatar
that is bad f'n ***.
I can't wait to see how this thing finishes up.
Old 12-30-2010, 09:38 AM
Eddie2011's Avatar
Thanks for the compliments, It will be a slow project since I do everything myself, including all the custom machined stuff. Its pretty time consuming, and it only gets worked on when I have a window between shop projects.
Old 12-31-2010, 08:24 AM
SuprJames's Avatar
WOW, now that is cool. Love hot rods, and this is an awesome build so I will definitely be following this.
Old 01-17-2011, 10:28 PM
Eddie2011's Avatar
So here is an update.... Got some new toys in last week.
Old 01-17-2011, 10:29 PM
Eddie2011's Avatar
This is alot of work since I do it all on my bridgeport. If only I had a cnc....... someday
Old 01-17-2011, 10:40 PM
AronZ28's Avatar
This is going to be epic when its all said and done. I've never seen anybody do a mid-engine configuration on a 30's Ford.
Old 01-17-2011, 10:45 PM
Eddie2011's Avatar
I have seen a couple actually, but they were always something cheesy like a northstar complete assembly shoved in the back or worse a toronado settup. I've never seen anything on this level which is why I wanted to do it. I have been planning this thing for a long time so now I need to get it done before someone beats me to the punch.
Quick Reply: 1937 Ford twin Turbo LSX
