tempo question for all lt1 owners
Old 01-04-2011, 12:05 AM
Big bird55's Avatar
Default tempo question for all lt1 owners
i want to make sure mine is running around what it should once i get it back together.
what temp. does your car usually run at when it is at full temp.
im doing a cam swap as well if that makes any difference in the temp. thanks
Old 01-04-2011, 12:19 AM
speed_demon24's Avatar
What temp. Does your car usually run at when it is at full temp.
Im doing a cam swap as well if that makes any difference in the temp. Thanks
165-200
Old 01-04-2011, 12:31 AM
Stocker94z's Avatar
185-200ishh
Old 01-04-2011, 01:17 AM
RamAir95TA's Avatar
No more than 185.
Old 01-04-2011, 01:20 AM
wrd1972's Avatar
194-196 98% of the time.
Old 01-04-2011, 01:32 AM
riceburnerZ28's Avatar
185-210 in the colder months
Old 01-04-2011, 04:51 AM
AZ2ENVY's Avatar
Colder months ...
160-170*
Warmer months ...
170-180*
Old 01-04-2011, 06:52 AM
DAVE00's Avatar
Originally Posted by ZL1LT1
Colder months ...
160-170*
Warmer months ...
170-180*
+1 - same here. Get the 160 deg thermostat.
Old 01-04-2011, 08:13 AM
VinR1's Avatar
Colder months ...
160-170*
Warmer months ...
170-180*
x3
Old 01-04-2011, 09:54 PM
great421's Avatar
FYI - Along with the 160 degree thermostat advice, if you can, flush out ALL the "Dexcool" coolant and then go with standard old school (i.e. - green coolant), not the orange Dexcool, and not the universal coolant; as the standard Prestone / Peak stuff has a greater ability to remove excess engine heat.
After the switch (with a 160 degree thermostat), my temps only hit 170 (MAX) even when ambient temps were in the triple digits (NC here). Oh, and standard Prestone coolant doesn't eat Aluminum as quickly as Dexcool either!
Old 01-04-2011, 10:04 PM
1_bad94Camaro's Avatar
With a 160* stat and an engine oil cooler at idle in south Texas summer it gets to 185 max. In the winter it barely comes off the peg.
