?are 9.50s realistic thru lt4 heads an intake..
Old 01-16-2011, 09:31 AM
Hit em Up's Avatar
Default ?are 9.50s realistic thru lt4 heads an intake..
I have been doing lots of research trying to figure out my next step..So many times people are saying stock intake is good until( Big Hp) like what? The heads I hear can flow round 300cfm worked properly @.600lift..I have a callies forged internal 11.8cr 396 with je pistons and rings gapped for spray.Im going to a custom grind sr cam but have to make decision on heads n intake first..Sorry I should those goals are with spray...any helpful advice appreciated...thx
Old 01-16-2011, 09:59 AM
Puck's Avatar
They are enough.
Ask Sikora
Old 01-16-2011, 10:30 AM
robsquikz28's Avatar
yep 9s are possible for sure
Old 01-16-2011, 10:31 AM
Hit em Up's Avatar
Thanks puck,,I feel like if its not broke then dont fix it..any other opinons out there,or point me to someone who has similar setup I could reference..thx
Old 01-16-2011, 11:00 AM
96capricemgr's Avatar
http://advancedinduction.com/AiHome.htm
LT4s will get it done on spray but there are better options. That car is NA. It went high 9s with ported LT1 heads and intake.
Old 01-16-2011, 11:53 AM
Hit em Up's Avatar
Good info 96capricemgr,ive heard nothing but good things about AI.If I sell my current heads soon AI is probaly going to get my business.If not mine are going to the shop and I will work with what I got..
Old 01-16-2011, 11:59 AM
AChotrod's Avatar
Yup it can be done and Im going for it.
Old 01-16-2011, 12:48 PM
Hit em Up's Avatar
Good luck,i will be following ur build..How do like ur nitrous outlet kit? Im thinking of going with one this time around.
Old 01-16-2011, 12:51 PM
AChotrod's Avatar
Its very bad *** and works great! I havent had time to hit the track with it but it works great on the street. I will upgrade to a direct port system someday so I can spray it a bit harder.
Old 01-16-2011, 01:11 PM
Hit em Up's Avatar
What computer system are u running if u dont mind me asking?
Old 01-16-2011, 01:21 PM
T/ALT1's Avatar
Yes, it's doable and I have the heads/cam setup to do it forsale. My goal was to run 9.20's-30's with this setup but I have changed directions. I am building my rollcage to 8.50 cert so my car needs to al least run 8's. My current 383 with LE3 heads/SRcam setup ran 10.80@127.8mph on pumpgas N/A and only made one n2o pass, 9.92@136mph on 100Hp n2o. Now I maybe stepping up to a BBC so I am selling this proven setup for cheap. Later
Old 01-16-2011, 01:23 PM
AChotrod's Avatar
Stock.
Old 01-16-2011, 01:51 PM
stock pcm, stock ported heads can get you in the 9s!!!
Old 01-16-2011, 05:08 PM
hitmanws6's Avatar
Ed Wright and Joe Overton were in the 9s with LT4 heads
Old 01-16-2011, 05:34 PM
Puck's Avatar
Indeed, and Sikora ran 8s with LT4 castings.
They get a lot of hate on here, but they have a lot of potential. If LT4s were made in more cars the gap between LT and LS cars would have been a lot smaller .
Quick Reply: ?are 9.50s realistic thru lt4 heads an intake..
