NEED HELP!! what rods are these??
Old 01-16-2011, 01:30 PM
9sec93's Avatar
Default NEED HELP!! what rods are these??
i bought a car and pulled the motor out and now im trying to figure out what is in this thing. it i sa 414" iron block. unknown 4" crank, rods in pics and forged pistons with no part number on them either. the rod bolts are carrillo so i assumed they were carrillo rods but they dont look like the ones i find on carrillos site. any help would be greatly appreciated
Old 01-16-2011, 01:36 PM
bww3588's Avatar
That's hard to tell. If there are no markings on them chances are they are either cheap ebay rods or really expensive custom rods.
Old 01-17-2011, 10:03 AM
RARON455's Avatar
Yeah, gonna be hard to tell without a marking, they look kinda like the lunati pro billet rods, but there are knock offs on those too.
Old 01-17-2011, 11:46 AM
Callies Performance's Avatar
Well, they are not ours, if that helps! Looks like the mating faces have been worked a bit, for clearance. Ours are already stroker ground.
-Adam @ Callies
Old 01-17-2011, 10:18 PM
9sec93's Avatar
-Adam @ Callies
actually that helps alot because i was told that they were callies but didnt want to post that up because i didnt think it was accurate anyway. thank you. actually i have another question for you. i have a 4" callies crank in my other motor. it has callies cast right into it then the right next to it looks like the numbers 389. i was just wondering which crank this was. again, any help would be greatly appreciated. here is a pic of it.
Old 01-18-2011, 07:40 AM
RARON455's Avatar
I ran into this on my callies crank also,,the number beside the callies name was just a forging no. not the part no. there was a number on the front side of the first crank throw that I used with callies to ID my crank had to pull the front cover off to see it though. it was engraved on the face of the throw.
Old 01-18-2011, 02:13 PM
9sec93's Avatar
i just did some digging from where i got the crank from and found out it is a magnum. ok so i figured that out. still wondering about the stuff in the first post.
Old 01-19-2011, 08:54 PM
9sec93's Avatar
ok i found out what the stuff in the first pic is.
lunati crank, lentz rods and wiseco pistons
Old 01-20-2011, 09:05 AM
Cool, we do engrave out cranks on the first counterweight. the first five digits are the serial number, and the second is the stroke. ^^^ I was going to say, that's either a DragonSlayer or Magnum!
The 389 is a forging number, nothing to do with the Models we produce
Old 01-20-2011, 10:07 AM
9sec93's Avatar
thanks for the info. that is good to know
Quick Reply: NEED HELP!! what rods are these??
