100 Shot '93 z28
100 Shot '93 z28
How would my car handle a 100 shot. basically stock check my SIG. I run 13.7. with DR and the 100 shot what do you guys think i could run? and what mods would i have to do to handle the Nitrous. I am also getting a chip for the car. Any help would be nice. I could tell pcmforless that i run nitrous i'm guessing they'll pull timing to help with nitrous. or would i be okay with the N/a chip. Anything will be helpful. thanks guys!
I was running 12.90's@107 in my car with about the same amount of mods 1.92 60' with a PCMforless mail order tune. My car was a standard tho. I sprayed a 100 shot and went 12.1's@114 w/ 1.96 60'. If you can hook I say about 8 tenths. All I did was run a colder plug. I think it was either a TR6 or a BR6EF. I didn't pull any timing. I think the rule of thumb is 2* for every 100hp. I usually run NA and don't spray a big shot even when I do spray.
I'm running 13.7 @ 99 and 60 ft time of 1.912. i was also having tranny heating problems. i think i fixed that and i should be around 13.6 or a little quicker. im hoping if i get DR's with the 100 shot and a tune, i could run atleast 12.8-12.6. possible i think...i hope lol
Yea, I don't see 12.8-12.6 being an issue if you have good bottle pressure. It was like 70* when I ran and I didn't have a guage to know what the bottle pressure was. I'm sure I was on the low side. I think your car would be significantly quicker if you were running a 3600 stall and some long tube headers instead of those shorties. Those are a couple things to think about if you're going to be modding the car more in the future. Good luck.
So figure I got Drag radials, a 3600 stall( mine actually doesn't say what it came with. it is a 10" non lock up. I am not exactly sure), 100 shot, and maybe drop 100 lbs off the car. You think i could get away with 12.5 or a little quicker? Thanks for the response! and those LT's seem so perfect. wish i had 300 bucks! i want them with a 3" Y + HF CAT and my borla. hoping for good rwhp! and 1/4!
You should be alot faster, I ran 13.17 through manifolds. Talk to Alvin @ pcmforless.
Well i had major tranny heat issues. i run high 1.8's 60 ft with street tires, i run high 8's 1/8 mile and a 13.7 1/4 at 99. what do you think i should be running? im thinking with the tranny cooler around 13.5ish. im hoping any way. well see this spring. but by 2012 i want to be atleast mid 12's. gimme some ideas guys
Not bad for a street tire, throw in a Yank SS 3600 and get some 1.7x 60's. It will improve the 1/4 times.
Trying to keep it a budget while i build another project. I may just keep my stall which by the way, im not 100% sure on the stall speed...its just a 10" non lock up. maybe keep it with street tires and some long tubes...and the 100 shot im not sure though
Something isnt right with your car.
