Blown head gasket.. Does this look ok
So i blew a headgasket.. My question is this.. This looks just like burnt coolant and it seems to rub off with some elbow grease.. Does it look ok? or is the wall trashed?
just wipe it off then when before you start the engine squirt a little bit of oil in each cylinder to burn them out clean, then change pull the spark plugs and clean them. im with Mart on this one, what is up with that nick in the piston, does not look like a happy motor. stock cam or not?
