Overheating
Old 01-31-2011, 06:16 PM
rich5368's Avatar
Default Overheating
On my way home from work today the car started overheating. I got it home and shut it off and started investigating. I immediately saw coolant puddling on the ground but it seems to be everywhere and I can't pinpoint a spot where it's generating from. It doesn't seem like it just dumped as much as just kinda poured over time. Anyone had a problem like this before? Could it be the waterpump?
Old 01-31-2011, 06:27 PM
96azz28's Avatar
Most likely your Radiator took a **** on you
this happened to me before I had a crack in the radiator.
Old 01-31-2011, 07:23 PM
rich5368's Avatar
Well that would lick *****...
Old 01-31-2011, 07:33 PM
96azz28's Avatar
it sure does
you could do a preasure test just be sure it was the radiator it will point out the where you have the crack
also check the hoses or even the sensor on the radiator mine popped out on me and car started to overheat
hopefully you fix it
Old 01-31-2011, 07:38 PM
rich5368's Avatar
Just looked at it now that it's cooled down. Radiator is full of coolant and it didn't leak all that much. Car did overheat and the heater was only blowing luke warm. Weird.
Old 01-31-2011, 07:42 PM
jim ravencraft's Avatar
Hi,
stuck thermostat??????????? You can also borrow a pressure tester from autozone/oreilly/etc. Have a blessed day.......jim
Old 01-31-2011, 07:48 PM
rich5368's Avatar
I was kinda leaning that way but was trying to figure out where the leaking fluid came from. Boil off from res maybe? Thanks Jim.
Old 01-31-2011, 08:00 PM
96azz28's Avatar
everything is original right?
if it is I wanna say the leaking could be coming from one of the hoses
the spring got rusty and got looser but idk thats what im guessing
Old 01-31-2011, 08:30 PM
rich5368's Avatar
As far as I know It's all original. I'm going to tear it apart tomorrow or wednesday and try and see what the heck. The fact that it's still full of coolant does kind of point to thermostat.
Old 02-01-2011, 03:00 AM
323steel36's Avatar
check if your coolant resevoir is stained or wet with coolant. Then for sure it will be the stuck thermo since that causes the car to overheat and spill out everything like crazy through the resevoir tank.
Quick Reply: Overheating
