water pump Question on instalation
Old Jan 25, 2011 | 11:53 PM
323steel36's Avatar
Default water pump Question on instalation
I bought a new water pump. Bought the gaskets, but do i need knew o ring seals for the driveshaft and water pump? If so what is the gm part # please help. And im also thinking of getteing new mounting bolts. Does anyone know the gm part # for the water pump mounting bolts?
this is a 93 trans am lt1.
Old Jan 26, 2011 | 03:19 AM
onephatZ28's Avatar
i would replace it if u are there
link for o-ring
http://www.rmsautoparts.com/proddeta...?prod=12553792
Old Jan 26, 2011 | 03:28 AM
onephatZ28's Avatar
3754587 Water Pump Gasket 2
9442012 Water Pump Bolts 3/8-16/ 2 1/4 4
14088753 Water Outlet 1
10198997 Water Outlet Bolts 2
10105135 Water Outlet Gasket 1
Old Jan 26, 2011 | 03:32 AM
onephatZ28's Avatar
Here is a list of part numbers some may find useful while doing routine maintenence on their LT1's.
ENGINE
10105379 Stock 48mm throttle body gasket
12524653 Intake manifold gasket set
12552469 Exhaust manifold gasket set
10168457 Stock .049" head gaskets (Aluminum heads)
12369145 Head Gasket Kit (includes intake/heads(aluminum)/exhaust/etc)
10128293 Front cover (timing cover) gasket
12552428 Front cover Optispark Seal
10128316 Front cover crank seal
10474278 Distributor drive shaft seal
12553792 Water pump drive seal
10217886 Water pump front seal
10128343 Water pump gasket (2)
12527740 LT1 Water Pump
10046089 Centerbolt Valve Cover Gasket
25171377 Oil Filter AC PF52(Duraguard)
25325403 Oil Filter AC PF52(Duraguard Silver)
25322836 Oil Filter AC PF52(Ultraguard Gold)
10108676 Oil Pan Gasket
12551589 Oil Filter Adapter gasket
10244495 Oil Filter Adapter o-ring
14090908 oil cooler tube seals (2)
17113381 F-Body EGR valve
12337972 EGR Valve Gasket
10055726 EGR Tube Gasket
25095452 PCV VALVE
10240678 PCV GROMMET
12556257 PCV PIPE
460483 Engine valve oil seal
10046089 iron head rocker cover
25121978 fuel filter
12370835 LT4 Extreme Duty Roller Timing Set
12555885 LT4 Roller Timing Set Cam Gear (95+ LT1) or 94 + B-body
12555886 LT4 Roller Timing Set Crank Gear (95+ LT1) or 94 + B-body
12555887 LT4 Roller Timing Set Roller Chain (95+ LT1) or 94 + B-body
10128346 LT1 Link-Chain Timing Set Crank Sprocket
10128485 LT1 Link-Chain Timing Set Link Chain
10126039 95+ LT1 Link-Chain Timing Set Cam Sprocket or 94 + B-body
10476885 Crank posistion sensor SEAL (96 only--OBD II)
22146273 left motor mount (LT1)
22146274 right motor mount (LT1)
12555714 Rear main seal housing gasket
17113086 Pressure regulator seal kit
10115875 1LE AC delete pulley
Old Jan 26, 2011 | 07:07 AM
shbox's Avatar
Oops, you better check those part numbers, because they are not for an LT1.
o-rings are GM PART # 12553792 (need two)
GM PART # 9423592 long bolt (need 4) 3/8-16 x 4
GM PART # 9440073 short bolt (need 2) 3/8-16 x 2
Old Jan 26, 2011 | 08:21 AM
onephatZ28's Avatar
i looked it up on bing, lol sorry if it is wrong
Old Jan 26, 2011 | 08:45 AM
wrd1972's Avatar
Just go to a parts house and look at their assortment of o-rings in the tackle box. Find a pair of o-rings that allows the coupler to slip snug over but can still be easily removed. IMO, these o-rings are for vibration dampening and not really sealing of fluids. They will cost less than a dollar.
GM would likely want $10 for the original parts.
Old Jan 26, 2011 | 11:01 AM
shbox's Avatar
$1.30 list price for the GM o-ring.
Old Jan 26, 2011 | 03:42 PM
323steel36's Avatar
ok thanks now i have to look for the water pump bolts having trouble finding any of them
Old Jan 26, 2011 | 03:49 PM
323steel36's Avatar
my question is the two orings one goes on the driveshasft right? and the other on the back of the water pump?
Old Jan 26, 2011 | 04:16 PM
leadfoot4's Avatar
What's wrong with the original bolts? I've had my w/p off and on a couple of times, over the years, for various maintenance "projects", and always used the OE bolts (with a dab of teflon thread sealer, of course)
Old Jan 26, 2011 | 04:17 PM
323steel36's Avatar
bs 17 dollars a piece for the water pump bolts. Wth ima go to autozone or use the same ones that are in the water pump.
Do you think if I use the same water pump bolts it will be ok?
Old Jan 26, 2011 | 04:19 PM
323steel36's Avatar
i guess your right. the same one should be fine. im just paranoid cause one of the guys botls in a youtube video snapped while trying to remove them.
Old Jan 26, 2011 | 05:00 PM
leadfoot4's Avatar
If you want to, you can put one of the o-rings on the back of the water pump drive "stub", and the other on the drive "stub" that passes through the front cover of the engine.
If somebody snapped a 3/8" bolt by removing it, either it was way too tight, or the guy was a klutz. IIRC, the torque spec for those bolts is 33 ft/lbs.
Old Jan 26, 2011 | 05:15 PM
shbox's Avatar
Yes and clean and grease the inside of the coupler.
Old Jan 26, 2011 | 11:43 PM
323steel36's Avatar
by any chance what kind of thread do i put on the water pump bolts when i put them back so they wont leak?
Old Jan 27, 2011 | 06:48 AM
shbox's Avatar
Thread sealant? Permatex high temp. Comes in a little tube you can get at most any auto parts place.
Old Jan 27, 2011 | 11:03 AM
SS RRR's Avatar
Village Troll
You only need sealant on the bottom two bolts. Just FYI...
Old Jan 27, 2011 | 01:45 PM
sempire's Avatar
I need to change my intake gasket. any little parts or gaskets I should consider changing at the same time? i saw a list of parts, but i'm wondering what I should consider.
Old Jan 27, 2011 | 01:56 PM
323steel36's Avatar
Thumbs up
thanks you guys for helping out
