how to get a 19 by 12 wheel to fit a 4th gen camaro ....
i know i posted a similiar thread last week but i want to run oem c6 z06 wheels on my ss so i can do the cts-v brake mod up front. wandering what i have to do to get the rear z06 wheels to fit with the 325-30-r19 tires.....would the bfh mod and cutting out the bumpstops do the trick? thanks.
I have C6 ZO6 wheels on my T/A. I had to cut the bump stops and their mounts off, cut a little corner of square-stock from the front of the wheel well, cut a section of the outside edge of the lower control arm (the fold-over) and BFH the hell outta the front of the wheel well. Also, the ridges along the inside face of the wheel well that spread out from the bumpstop need to be cut down their length and hammered flat.
someone on here by the name of strokerB had them on his LT. He said it took alot of BFH and no cutting or grinding of any sort but since those wheels have corvette offset, they stick out a little bit.
https://ls1tech.com/forums/wheels-ti...kes-355-a.html
There is a member on here that has a black SS I believe on gunmetal spyders. He got them from 6LE. Man that car is beast! I have a pic. here you go.
Hope he will chime in.
That tire looks like it sticks out so far from the fender. You'd have to have an extremely stiff suspension setup to keep from making tire to fender contact.
