.030 Cometic/LS6 heads and MS3 is Ok??
I both a set of LS6 heads and a MS3 @113 ls to put it in my 99z28. Now if i use cometic head gasket .030 quench with that combo i going to have any problem with PV clearance? My motor is completely stock,factory pistons.
Any opinion is welcome. thanks guys.
Everyone on this forum uses .040 gaskets, but I when I talked to a few vendors they suggested a .045 to be safe. For the 2-3hp difference its not worth it.
Ok my goal for summer is have the car ready i going to use the ported LS6 heads ,MS3 and 150-175hp shoot. You think that the factory head gasket can hold it?[/QUOTE]
I hope so I plan to run a similar combo except unported 243 and a 150 shot (then a 200) at the end of the season.
Now ok i going to go with factory head gasket to be safe in PVC. Thanks so much guys for the Help.
I'm using a LS6 intake with factory ported T/body, ASP pulley, LT headesr, volant cai ,
42 lbs injectors to complement the MS3 and 243 heads with tune.
You think with this combo is posible to put 550 rwhp in automatic trans. car?
