Need help w/ fuel pump wiring
I am swapping a 99 T/A harness into a 95 T/A and I'm looking for some help figuring out which wires get used to hook 99 harness up to 95 fuel pump?
If you know how all the wires from the 99 harness work which should goto the 95 fuel pump and sending unit?
ok the fuel pump works but the gauge does not from the diagrams i've looked at it seems the 95 sending unit uses resistance to move the gauge and the 99 uses voltage to send the gauge signal.
Anbody know if there is a way to make this work I am using the 99 gauge cluster but i'm assuming I will need an LS1 gas tank and sender is this correct?
