t56 with stock long block 6.0
Old 02-06-2011, 09:59 PM
thefastlife's Avatar
Default t56 with stock long block 6.0
i have heard horror stories about a t56 not working with certain stock 6.0 if someone could help i am trying to find out what years of 6.0 i can and can not get that will bolt straight up thanks a bunch
Old 02-06-2011, 10:05 PM
98silvermaro's Avatar
I got an 03 Escalade block (GENIII) in my car and everything bolted right up. If you stay with a GEN III block everything will bolt right up. If you go with a LS2 which is GEN IV I believe, I think the knock sensors and the cam position senors are in different locations or different plugs
Old 02-06-2011, 10:07 PM
so the genIII block would be a lq4 or lq9 im kind of confused
Old 02-06-2011, 10:15 PM
yes... mine is an LQ9. you can still put an LS2 if you want to save the extra weight. like i said I think its just a couple different connections
Old 02-06-2011, 10:17 PM
well the issue i hear was something about the trans not bolting up due to the crank shaft ? it wouldnt clear
Old 02-06-2011, 10:22 PM
I know you can put a T-56 behind a LQ4, LQ9, and all the LS motors
Old 02-06-2011, 10:25 PM
lol ok thats what i was looking for
Old 02-07-2011, 01:39 PM
BES Stroked Nova's Avatar
i think it was 99-00 6.0L's that the crank was different.
Dont forget that pilot bearing during install!
Old 02-07-2011, 03:33 PM
jmm98LS1's Avatar
^^^Correct. The 99-00 LQ4 crankshaft has a longer rear flange that can only be used with 4l80e/th400/th350 transmissions. A 4l60e or T56 will not bolt up to these engines. Starting in 2001 they went to the shorter flange that bolt right up to a T56. These early engines are easily identifiable by their iron cyl heads heads instead of aluminum 317 castings that came on the '01+ engines.
Old 02-07-2011, 07:36 PM
Cool that's what I needed to know thank you guys a ton
