Cannot go into any gear?
My T56 just all of a sudden will not go into any gear at all. I've never had this problem before. Clutch fluid is fine and the shifter is fine. Is my clutch done?
engine off - goes in gear?
engine on - won't go in gear?
If yes / yes, your clutch release hydraulics system is likely not working. Start by looking for leaks at the master cylinder (in-cabin) and the line (firewall to bellhousing) and at the bellhousing (leaking slave cylinder.)
Transmission was rebuilt a few months ago.
Well I tried again tonight and now it goes into a few gears but not all of them, with the engine off.
1st - Always goes in
2nd - Only goes in half way
3rd - Doesn't want to go in, and I don't want to force it
4th - Sometimes goes in
5th - Always goes in
6th - Didn't really try
