A Metal Polished Air Lid?!?
I have NEVER EVER seen one of these. Now i dont work for the company that sells them so calm down. I am looking for a new air lid since my SLP one rubs BADLY on my SS Hood. I came across this one on Ebay.
I am unsure if I actually like it. But has ANYONE EVER SEEN ONE INSTALLED? I just cant imagine it looking too good.
Anyways, here it is:
http://cgi.ebay.com/ebaymotors/ws/eB...8099&viewitem=
That lid is bad *** and all you need to do is polish it up a lil better. I would trade my MIT CF lid in a heart beat for this one. A guy has one on here with a nice super charger badge on it.
It's been talked about before.
Might want to check out this thread it has some cool pics in it.
https://ls1tech.com/forums/appearanc...l-air-lid.html
But for me it's a bit too much bling.
do a search. the SS ebay ones are super heavy, shitty quality/fitment/welding/finish. ie the tb didnt line up w the intake, the box didnt seal to the shroud, etc.
if it was aluminum or light gauge stainless then maybe, if you didnt mind the crazy heat soak vs the nice showeyness.
nope, doesnt get hot at all.. if you think about it, it never touches metal.. plastic base and bellows is it.. aside from ambient temps, theres nothing to make it get any hotter than the rest of the engine bay.. i really liked my lid a lot, i just wanted something that matched.. whoever wants one should get one.. but with everything custom, expect some fitment tweaks... the AIR hole needs plugged and the iac needs a thicker gromet... you will need to put a seal in the lid too... the fit is actually just as good as my new whisper lid...
1 Post
Ahh but thats the thing, the ambient air in the bay should get absorbed by it. Theres a reason they make radiators black so that the heat transfer or emissitivity is greater. Hell, it prob should matter much though..Specially if your running a cai or something
the lid does not get hot.. ive owned it and put about 7k miles on it... NO problems at all... dont listen to anyone else unless they have used it.. I HAVE USED IT.. it is an awesome lid.. really.. here is all i had to do to use it:
IAC sensor gromet hole is bigger than the stock one, get a bigger one from Autozone... cost me $2
Plug the AIR hole in the side if you dont have it... you can use the plug from the !help section in the store.. the one where you tighten the bolt and nut and it compresses the rubber gromet and makes it swell.. i used the same one when i plugged my EGR hole on top of my intake.. or a 1 1/8" body plug or similar will work too
$3 maybe...
put a seal on the inside of the lid.. all lids have it so its not like your using "african inginuity" on it... i got a whole roll for $4
the neck is exactly 90mm, the maf end will fit if you file the edge of it off smooth instead of having that little v hump on the end of it.. i used a fernco fitting on mine, or you can slit the ends like most of the plastic ones are.. the neck is long on purpose, you can easily cut it down...
That lid is worth it, and every time you raise your hood people will notice it... the only reason i traded for my whisper lid is because i am going to put an acrylic plaque behind a cutout with an led in it..
$3 maybe...
There was a guy on here not too long ago who bought one off Ebay(i dont know if its any of the previous posters) But you might be able to find his thread. He said it fit like ****, the weld's looked like pigeon ****, and it had swirl/scratches all over it, i honestly have never seen or used one though. My honest opinion thou is i think it looks cheap and tacky, i would not own/buy one.
Captain Double Post
Yeah not a fan,and for who ever said someone has one with a supercharger logo on it,I'm sure that is the pro charger kit,not a air lid .this might look good with some kind of decal or something on it,but by it self it doesn't look good imho,maybe with one of these on there it would look better if there was a lot of bling going on,(not my car another members)
