Help!!!
Old 02-13-2011, 04:36 PM
unleashedperformance's Avatar
Default Help!!!
can somebody tell me the difference between the driver side and passenger side heads. i bought a lt1 that is completely in pieces. i cant figure which head goes to which side.
Old 02-13-2011, 04:41 PM
That's MISTER MODERATOR
Paul Bell's Avatar
I don't mean to come off as a wise *** but if you don't know this, perhaps you shouldn't be fooling with engines without some experienced help.
The heads are identical and can go left or right.
Old 02-13-2011, 04:44 PM
well i knew that. but isnt there a tube that coolant travels through going from the passenger side to the driverside on the back of the head?
Old 02-13-2011, 04:55 PM
Lawhead's Avatar
Almost 100% sure you can't do that because of the steam pipe in the back.
So you don't sound like a "wise ***" at all
Old 02-13-2011, 04:56 PM
gregrob's Avatar
They cannot go either way as "wiseass" up there stated.
The ports for the coolant crossover must be on the rear. Also the Drivers side head will have a threaded port for the coolant temp sensor...
Old 02-13-2011, 04:59 PM
thanks guys that did it for me i see the port for the coolant temp sensor.
Old 02-13-2011, 05:07 PM
Paul Bell's Avatar
You’re all wrong.
If you can’t give accurate advise, don’t.
The heads are identical.
Both ends of the heads have steam ports. There’s a plug in one end which would end up at the front.
Both heads have a temp sensor port, there’s a plug in the port on the right head.
Old 02-13-2011, 05:18 PM
gregrob's Avatar
Im still correct. Im well aware the heads have plugged fittings that you can use if necessary but I highly doubt he wants yo go to that trouble. Come on...
Fact remains as they set in front of him they will only work one way.
Old 02-13-2011, 05:22 PM
Lawhead's Avatar
They are not the same just think about it flip the head there is a hole in the front but its way smaller then the steam holes in the back.
I can take pictures if you like my heads are sitting right on the bench
Old 02-13-2011, 05:30 PM
RamAir95TA's Avatar
Fact: The head castings (notice I said CASTINGS, minus the plugs) are identical.
If the plugs weren't in the heads you couldn't tell the difference between the two. With the plugs installed in FACTORY configuration, they can only go on one way.
Old 02-13-2011, 05:31 PM
gregrob's Avatar
Werd.
Old 02-13-2011, 06:00 PM
Lawhead's Avatar
Well hopefully he's not trying to just put casting on his motor and put it back together
Old 02-13-2011, 06:49 PM
gregrob's Avatar
That's either the smartest, or dumbest thing you've ever said. I can't decide..
Old 02-13-2011, 06:53 PM
Lawhead's Avatar
You talking?
Old 02-13-2011, 06:56 PM
Lawhead's Avatar
Hate this phone
didnt even mean to do that was supposed tl be a text message lol.
But my heads you can not swap them for each other just went out and looked
Old 02-13-2011, 07:30 PM
gregrob's Avatar
Just giving you ****
Old 02-13-2011, 10:14 PM
the engine was a rebuild project and i got it cheap so im just putting it back together for resale.
Old 02-13-2011, 11:13 PM
Village Troll
SS RRR's Avatar
The way the heads came from the factory the passenger side head will have a plug on the side that taps into the water jacket between the 6 and 8 exhaust ports whereas the drivers side will either have a temp sensor or open bung for the temp sensor between the 1 and 3 exhaust ports. There will be plugs on the front of the heads whereas the rear will be open bungs for banjo bolts for the steam pipe.
Both heads in the above picture are facing frontwards. You can see the plug that taps into a waterjacket in the pass. side head.
Old 02-13-2011, 11:29 PM
Z28Camaro30Ann's Avatar
Just look at which side the plugs are currently on. the side with the plug in is the FRONT of the head in THAT SPECIFIC CONFIGURATION. If you want to change it you need to change the plugs on both heads to the opposite side. it takes literally 1 minute to do, but if you don't need to, then don't do it lol. Just install them with the plugs to the front and your good to go!
Quick Reply: Help!!!
