engine build ?s
engine build ?s
Fixen put my heads cam intake 355 back together. Will the clevite p bearings be ok. The part #s i came up with r ms909p and cb663p. Wat oil pump should i go with. Is the .026 head gasket part # 5716g. Will b sprayin around 200 and spinnin it to 6800. Ive already did this once but cant remember part #s
Get yourself a stock replacement pump from a good manufacturer. If the machine work is good, and the assembly is good, you will see 80lbs psi on a cold start and it will settle into 25-30lbs at a hot idle. An sbc/lt1 oiling system is one of the best around. No need to fix what ain't broke.
