1998 trans am pcm diagram help!!!
Old 02-14-2011, 08:05 PM
slp1300's Avatar
Default 1998 trans am pcm diagram help!!!
Hi can anybody help me on where can i find the pcm wiring diagram for my 1998 trans am, because im having trouble with a code (P0785) so i can fix my car. Any help would be greatly appreciated!!!
Old 02-14-2011, 08:39 PM
flame's Avatar
The code is for the 3-2 shift solenoid. The solenoid resistance spec is 20-32 ohms. I attached a pic to help locate it.
Old 02-14-2011, 08:59 PM
slp1300's Avatar
thanks for your quick answer, as of right now i checked the solenoid and it is fine, i need to get the pcm diagram so i can check all the wires to see if on is cut or something wrong with them.
Old 02-14-2011, 09:01 PM
slp1300's Avatar
[QUOTE=slp1300;14505244]thanks for your quick answer, as of right now i checked the solenoid and it is fine, i need to get the pcm diagram so i can check all the wires to see if on is cut or something wrong with them.
do you know were can i get the pcm wires diagram??
Old 02-14-2011, 10:04 PM
2xLS1's Avatar
Attached Thumbnails 1998 trans am pcm diagram help!!!-p0785.jpg   1998 trans am pcm diagram help!!!-a4-connector.jpg
Old 02-17-2011, 01:29 PM
slp1300's Avatar
Everything in the trans seems to be ok i need to check all the wiring from the pcm to the trans, can anybody help me get the pcm wiring harness diagram so i can check the wires? thanks
Old 02-17-2011, 05:46 PM
flame's Avatar
If the only code is the one listed above then there is only 1 wire to worry about. The power for the solenoid is the same wire for all so if one works then power is good. The control wire from pin 34 at the pcm is all you would have to check.
Old 02-17-2011, 09:32 PM
MontecarloDrag's Avatar
These are the 98 Transam PCM wiring diagrams:
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 02-19-2013, 06:09 PM
HibachiZ28's Avatar
Thanks for the PCM diagram!!
Quick Reply: 1998 trans am pcm diagram help!!!
