vented opti dead again...what to do?
Old 02-18-2011, 09:52 AM
katz_2003's Avatar
Default vented opti dead again...what to do?
Built a 385 stroker with ai h/c/I. First optispark (oem) lasted all of break in. I took the car fairly easy keeping the rpms down. After I got it broke in decent, I raced a h/c ls1, beat him fairly easily....next morning car wouldnt start. Replaced opti with brand new ac delco vented opti...car ran perfect for two days, on the 2nd day raced a lt1 355 h/c car, beat him lol. Went home parked the car....guess what?? Went to start car next mornin....nothin! No spark....no wires lose or anything like that. Is it because the rpms are getting too high and frying my opti or what?? Do I replace it with another oem opti? Or go another route?
Old 02-18-2011, 09:59 AM
katz_2003's Avatar
On the last race I never even got out of 2nd gear cause I pulled him so hard. I shifted at like 6600...no where near the 7000-7200 this thing should pull to....
Old 02-18-2011, 10:00 AM
Mooneyed's Avatar
have you pulled them apart afterwards to see if your shattering the rotor inside the opti?
Are you replacing the whole unit or just cap and rotor each time?
Gojira94's Avatar
Before you spend any more, do this check:
http://shbox.com/1/4th_gen_tech2.html#opti_test
Sounds like 2 identical failures with OE optis is unlikely. I'll venture a guess that you might have a pigtail going south, not staying tight, then incidentally corrects itself when you R&R the opti. Or something else in secondary ign. with issues that fixes itself due to handling/ wiggling during R&R. Opti RPMs are only half engine speed, remember...
Old 02-18-2011, 10:04 AM
katz_2003's Avatar
I replaced both pigtails with each Install and with new motor..so both have been new. They have both been ebay pig tails but oem optis
Old 02-18-2011, 10:06 AM
katz_2003's Avatar
Havent. opened up 2nd opti yet...first opti was code 36 high something the scanner said and all insides looked good to me...wheel was fine
And they have been whole units both loc tighted
Old 02-18-2011, 10:16 AM
Gojira94's Avatar
Ok, code 36 on first opti is hi res; legitimate failure... if it was used and became part of the rebuild and wasn't new. How about the second one? A code 16 or 36 on that one? If you got the same code then have a look at the harness end of the pigtail connector as well.
Check the car's harness, that is- not the end of the pigtail.
Old 02-18-2011, 10:31 AM
katz_2003's Avatar
The first opti was a old oem base with new msd cap and rotor. I also put the msd c&r on my new oem opti. Ran perfect not a miss, nothin until I really got on It (66-6700) at most while racing Its somethin in the base going bad it seems from higher rpms?? The eBay harness looked good to me...do they burn up somehow? First opti looked perfect inside? Does the electrical part go bad inside?
Old 02-18-2011, 10:39 AM
Gojira94's Avatar
So do you have a code on the (new) one that you find suspect?
I had the same scenario with my green car rebuild. Old opti looked fine, put MSD cap & rotor on it, ran it hard a bit and got a code 36. Mine had shaft bearing bits to flake out and pollute the insides and clog up the encoder. I have a theory about the discs: If they're warped enough to rub slightly on the inside of the optical encoder, it creates heat like you'd see patterns of on a warped rotor. Heat is what kills encoders, but it normally happens over a long period of use. warped wheel-induced friction can do it quickly, I'd think.
You said both your discs looked good- did you turn the opti with the shaft and watch the wheel as it went around to look for wobble/ high spots?
Old 02-18-2011, 10:47 AM
katz_2003's Avatar
I didn't turn it...I just set the old aside, threw on the new and it worked perfect so I wasn't worried about it lol. Ill check it out this weekend and pull the new one off andcheck it out. I haven't checkrd foe codes yet either but will do that as well this weekend. Thanks for all the help so far man
Old 02-18-2011, 04:14 PM
RamAir95TA's Avatar
Make sure your camshaft dowel pin is not too long. You have an aftermarket camshaft - most of them come on the long side and you trim it to fit (AI usually does this for you but it doesn't hurt to check). If the pin is too long it puts undue pressure on the rotor which can seriously accelerate failure.
Additionally, make sure you're getting good vacuum through the vent lines. A plugged flow reducer and/or backflow prevention valve will cause an almost immediate build-up of excessive ozone gas, which can cause all sorts of issues.
Old 02-18-2011, 06:33 PM
katz_2003's Avatar
Thanks alot for the help everyone....I don't know what happened but I put on my other new opti harness and the thing is flawless now...then I switched them back around and now everything is fine. I don't know if something somehow came lose on the harness plugged intotge opti or what but I am RELEAVED! thanks again everyone! Im lovin ai's h/c/I on thr car!
Quick Reply: vented opti dead again...what to do?
