Knock sensor code P0322
Old 02-18-2011, 06:50 PM
AgentLS1Z's Avatar
Default Knock sensor code P0322
I've been getting this code for about a month now on my 02 z28. How do I get rid of it?
Old 02-18-2011, 07:17 PM
DPleasent's Avatar
Was it a P0332 ? If so its the rear knock sensor (sensor B) causing the code which is the one that always sets a code. Usually due to water leaking in on it and causing it to rust. I would replace the rear knock sensor.
Old 02-18-2011, 07:19 PM
AgentLS1Z's Avatar
Okay sounds good. Is it accesible, or is it hard to get to?
Old 02-18-2011, 07:27 PM
AgentLS1Z's Avatar
sorry actually its a P0332 code! Ive been getting water in the computer too. Maybe its due to the water in the computer? One of the pins in the computer connector corroded away. Should I get a new upper pin connector for the computer?
Old 02-18-2011, 07:32 PM
DPleasent's Avatar
Its located under the intake manifold. Pretty easy to get to once you pull the intake. The sensors runs about $50 at a dealer. Is that broken pin on the pcm side or is it a damanged connector terminal. Either way I would fix that first.
Old 02-18-2011, 07:37 PM
AgentLS1Z's Avatar
its a damaged connector terminal...idk how the hell water is getting in there. it has the orange gaskets around the pin connectors. water is just getting into the top connector.
Old 02-19-2011, 01:49 PM
AgentLS1Z's Avatar
I'm also getting a P0171 code along with the P0332 code. Could they be related?
Old 02-19-2011, 02:30 PM
DPleasent's Avatar
The p0171 is a lean code. I think its bank 1. You could have a vacuum leak, bad o2 sensor or dirty maf sensor. But its not related to the knock sensor code. Does you scan tool indicate what dtc is mil requested ? It maybe a history code.
Quick Reply: Knock sensor code P0322
