water coolant
Old 02-20-2011, 03:43 PM
brians4thgenmaro's Avatar
Exclamation water coolant
i have a 1998 camaro 3.8l what is the name of the part that is connected to the hoses for the radiator when i get around 3500 rpms it starts spilling everywhere i need help fast
Old 02-20-2011, 05:28 PM
LS6427's Avatar
Hose clamps.....
Old 02-20-2011, 06:23 PM
it the from engine plateif thats what u call it
Old 02-20-2011, 06:29 PM
LS6427's Avatar
what?
The upper hose connects to the top of the water pump and a clamp holds it on.
The lower hose connects to the thermostat housing and a clamp holds that on. The t-stat housing is then bolted to the water pump.
Old 02-20-2011, 07:11 PM
i found out whats its called it the timing cover gasket that is leaking thats what im hoping i dont want to replace the timing cover
Old 02-20-2011, 08:57 PM
BRUTL's Avatar
yup, on 6 cylinder cars, that is a very common leak. They are setup just like an old ford. I just did this repair the other day at the shop.
Old 02-20-2011, 10:05 PM
LS6427's Avatar
You have coolant leaking from the timing chain cover........thats a first.
Old 02-20-2011, 10:23 PM
RedHotG8's Avatar
It's called the water pump and make an effort to write proper english so we can understand you. This isn't first grade dude.
Old 02-20-2011, 10:33 PM
LS6427's Avatar
lol yea, I thought I made it clear to him in post #4........
I thought after "BRUTL's" post there was something I didn't know about the V6's...so I didn't post anymore.
Old 02-20-2011, 10:50 PM
RedHotG8's Avatar
He asked:
Well the hose doesn't connect to the timing cover, it connects to the water pump.
Here's what the GM service manual says:
Old 02-20-2011, 10:51 PM
vette0009's Avatar
I believe your problems are a whole lot bigger than a timing cover Dude !
Here
3.8L Engine
1. Disconnect the negative battery cable.
2. Drain the cooling system into a suitable container.
3. Remove the serpentine belt.
4. Disconnect the radiator inlet hose from the water pump.
5. Unfasten the water pump pulley bolts/screws and remove the pulley.
6. Remove the water pump pulley retaining bolts, then remove the pump from the vehicle.
7. Remove and discard the gasket and thoroughly clean the gasket mating surfaces
To install:
1. Position a new water pump gasket, then install the pump. Secure using the water pump retaining bolts/screws and tighten to 11 ft. lbs. (15 Nm), plus an additional 80 degree rotation.
2. Install the water pump pulley and retaining bolts. Tighten to 115 inch lbs. (13 Nm).
3. Install the serpentine drive belt.
4. Connect the radiator inlet hose to the water pump.
5. Connect the negative battery cable.
6. Fill the cooling system. Start the engine and check for leaks.
http://www.fixya.com/cars/t5207944-s...ater_pump_1995
Old 02-21-2011, 04:23 AM
thats the wrong engine repair.i do not want to replace 2. I only want to replace 3
