Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Finally lowered the V this weekend.
Old 02-20-2011, 07:27 PM
Vcious04's Avatar
Default Finally lowered the V this weekend.
I will start off by saying, DO NOT FORGET TO ROLL THE FENDER LIP'S IN... trust me. Lickily no damage by it did scare the sidewalls a bit. I am running slightly larger tires all around so stock size might not be needed as bad.
I built my own rear lowering plates with 3/8" plate with DOM roll cage tubing about an inch high all mig welded together (sorry no pics, wish I would have).
Anyways, rides real nice, little rougher than stock, but well worth it in my opinion.
Old 02-20-2011, 08:04 PM
TheLAW's Avatar
Nice.
What springs did you use?
LAW
Old 02-20-2011, 08:05 PM
siggyfreud's Avatar
Looks great. Really low though hehe. What did you use to darken your chrome trim?
Old 02-20-2011, 08:18 PM
Vcious04's Avatar
Originally Posted by TheLAW
Nice.
LAW
Thanks!
Stock, cut 1 1/4 off the front, 1 1/2 rear.
Old 02-20-2011, 08:20 PM
Vcious04's Avatar
Thanks! Yeah, it does sit low, but it seems to clear everything so far.
I actually painted them black, then rubbed the paint off with some thinner to give it a darker chrome look, esp in the crease's and low area's.
Old 02-20-2011, 08:44 PM
JNR_Design's Avatar
Yeah, does look good lowered, although hate to be the one to have to try and lift it up (working on) and avoid the curb stops and driveways These cars do sit up pretty high in the middle stock, that's for sure!
Maybe the pic is deceiving, but is your front camber pretty out of wack, or maybe you will be fixing that?
Old 02-20-2011, 08:47 PM
Vcious04's Avatar
Thanks, I'm sure it effected the camber a little bit, but not by the human eye. The pic kinda gives it that effect I think. The last pic show's the front camber in a better perspective.
Old 02-20-2011, 09:45 PM
itsslow98's Avatar
Looks better then stock height, but a tad too low for me. now get some 06/07 center caps.
Old 02-21-2011, 12:45 AM
liqidvenom's Avatar
looks nice, better a bit low then at its stock height. what did you use to roll the fenders?
Old 02-21-2011, 01:31 AM
chitown21y's Avatar
Looks nice a bit low but nice!
Old 02-21-2011, 07:27 AM
tony tone's Avatar
as soon as i saw it i knew it was going to be too low for some... but i'll be the one to say it looks perfect! although i personally would've cut something other than my stock spring, the end result is awesome.
i can see those meaty tires giving you some fender issues. i rolled mine with the hubcentric machine that literally "rolls" back and forth on the fender until you've achieve desired fitment before i even slammed it because with the aggressive wheel i was running i knew there was no other option.
i can almost guarantee you you're going to need some camber adjustment. our cars have adjustment points both front and rear that a good alignment shop can modify to your preference. no "camber kit" required. i for one stayed negative all around just a degree or two so i could tuck the 285s in the rear on a 10.5 wheel.
well done, op.
Old 02-21-2011, 07:29 PM
Strokinit383's Avatar
Looks great!
Old 02-21-2011, 07:37 PM
D Block's Avatar
Sits just right. I like it!
Old 02-21-2011, 10:34 PM
A-Bomb's Avatar
That thing is on the ground! I likes.
Old 02-21-2011, 11:06 PM
whisler151's Avatar
Looks clean.
Old 02-22-2011, 09:02 AM
JD03Cobra's Avatar
That front end would shovel snow here in MI...I like it but could never drive it during the winter months.
Old 02-22-2011, 10:04 AM
MIGHTYMOUSE's Avatar
looks great man but you most likely are in the market for some narrower / lower profile tires.
Old 02-22-2011, 11:19 AM
liqidvenom's Avatar
i would drive it like that and park on the street if i couldn't clear my driveway.
Old 02-22-2011, 11:50 AM
tony tone's Avatar
my car is 22" off the ground based on a measurement from the middle of the fender down. another measurement from the front bumper was 2.25"...
i wouldn't have it any other way.
Old 02-22-2011, 10:49 PM
Loud02ss's Avatar
love it. perfect for my taste. nice job.
Quick Reply: Finally lowered the V this weekend.
