unhooking motormounts
Old 02-22-2011, 07:51 PM
matman88's Avatar
Default unhooking motormounts
How do you remove the through bolt on the motor mount? the bolt that holds the motor to the mount is in the way of the through bolt's lip and the head of the through bolt is in the way of the motor bolt.
Old 02-22-2011, 08:08 PM
greenZ96's Avatar
remove both bolts
Old 02-22-2011, 08:14 PM
5_LTR_ETR's Avatar
read again.... he obviously can't remove either... sorry i have no answer for you. i'm changing motor mounts in a couple days too so hopefully someone chimes in.
Old 02-22-2011, 08:29 PM
matman88's Avatar
I'm sure somebody on here has taken there LT1 out or lifted it at some point and it's hard for me to believe that nobody has had this issue but maybe I am the only person who experienced this... i hope my mounts aren't shot.
Old 02-22-2011, 08:39 PM
Village Troll
SS RRR's Avatar
You have to displace the weight of the engine onto a jack. Once you do that then the bolt will slide right out.
5_LTR_ETR's Avatar
speaking of lifting it.. lift it!! wouldn't this spread the bolts farther apart to let 1 slide past the other? just a thought. I have no idea
Old 02-22-2011, 08:41 PM
5_LTR_ETR's Avatar
ya what ^he^ said. i was a lil late on that one
Old 02-22-2011, 08:43 PM
Gojira94's Avatar
Hmmmmm... if they're sagging that much, how about using a jack to push one side up a little- or a piece of 2x4 wedged between the floor & the side of the block; tap it with a hammer to wedge it and lift one side of the engine maybe 1/2- 3/4"?
Last pair I did was pulling the engine in my current project. They came out pretty easy with a socket on one end, closed end of a combo wrench on the other side. Think it was socket front, wrench on back. Has resistance almost all the way, but it comes off. You can tap out the through bolt with a socket extension, with a little upward lifting force on the engine. A hoist is best for this, but a jack will do if you're careful and have an extra pair of hands.
Old 02-22-2011, 08:44 PM
matman88's Avatar
I have it displaced on the jack and the pin slides out about hafl an in until it hits the other bolt...
Old 02-22-2011, 08:47 PM
matman88's Avatar
GOT IT! i had to play with the jack a bit and slide the bolt back and forth a few times nbd
Old 02-23-2011, 06:08 AM
Village Troll
SS RRR's Avatar
One other thing to remember, if you can't find the sweet spot with the motor jacked and the bolt free, just start twisting on the bolt and it will thread itself out.
Old 02-23-2011, 09:09 AM
BigD383lt1's Avatar
If I remember correctly I think I removed the bolts on the block then lifted the motor enough to give me clearance... if not the other way around there is nothing easy in these cars!
Old 02-23-2011, 09:32 AM
jaycenk's Avatar
I think I remember what he is talking about but the rubber in my driver side motor mount was crushed and the one on the block saged in the way of the long bolt that joins the two halfs. Time to change them.
Quick Reply: unhooking motormounts
