Lt1 longtube headers install?
Old 02-24-2011, 12:22 PM
MAROBOY_TRAV's Avatar
Default Lt1 longtube headers install?
Okay so I am thinking about installing my long tube headers in myself insted of Payin 300bucks.. Any advice on the easiest way to get the passenger side in? I believe the driver side will go on good it's just the passenger side that makes me second guess doing it myself.
Old 02-24-2011, 12:24 PM
BigBadWhitey's Avatar
What brand of header are you going with? EGR fitting or no?
Through the bottom is the easiest (maybe only way?), and on the passenger side my only problem was the dipstick, which i had to remove then put back in, and my pacesetters with EGR fittings bumped into this stupid little metal flare on the firewall that i had to file about 1cm.
The following users liked this post:
BLK97 (04-23-2021)
Old 02-24-2011, 12:25 PM
quik95lt1's Avatar
jack the front of the car up about 2 feet in the air and wiggle it in from the bottom.........or put it on a lift......it goes right in if you go through the bottom......
Old 02-24-2011, 12:39 PM
boostedlt1's Avatar
the air/egr fittings make installing them a pain in the ***. just installed some emission legal pacesetters on monday, such a pain in the ***! lol (also didn't help that the car was a 94 and has the larger transmission case)
i have the pacesetter "race" ones on my car. those ones just slid right in no problems what so ever.
Old 02-24-2011, 12:50 PM
93M6Formula's Avatar
I put both of mine in from the bottom and they slid right in. I had to remove 4 spark plugs so that they would go on easier though. Also had to remove my oil cooler because the primaries were hitting it. It's really not a bad job to do, just sucks doing it yourself.
Old 02-24-2011, 04:44 PM
I was thinking about going with the pacesetter Longtubes. I want the model that don't have a EGR port. I believe the driver side will b pretty easy but thanpassenger side is the side that's having me second guess..
Old 02-24-2011, 05:25 PM
95mysticta's Avatar
I installed the emissions style pacsetters and for me i personally slid the drivers in from the bottom and unbolted the passenger side motor mount and jack up the motor and the header slid right into place. All cars are different and you'll have to play around with it to see what works easiest for you. Be prepared for cut up knuckles
Tolley's94z28's Avatar
Patience, a good metal working hammer, and a lift lol
Old 02-24-2011, 05:26 PM
oh, and for gods sake, dont install the shitty gaskets that pacesetter gives you!!! buy something better!!
Old 02-25-2011, 02:53 AM
Village Troll
SS RRR's Avatar
On an auto car it is far easier to slide a LT header in the passenger side. I'm thinking it's because the bellhousing is shaped a bit differently. Every manual car I've ever done I've had to jack the engine of its motor mount.
Old 02-25-2011, 03:34 AM
97 texas ta's Avatar
Yes I agree with tolley get copper gaskets
Old 02-25-2011, 07:30 AM
quik95lt1's Avatar
nahhhh dont worry it will go right in.......
yea remflex gaskets FTMFW!!!!! check em out........i've blown out every header gasket ive used...aluminum, copper, paper, carbon.....the only ones that lived were remflex grapphite.....and theyre cheap too
I've installed them on all auto LT cars did a few M6 LS cars and never had an issue but im sure thats a totally diff story....
Old 02-25-2011, 08:35 AM
Village Troll
SS RRR's Avatar
It could be a totally different story. Who pissed in your fruit loops today? Anyway, I forgot to add the only headers I've ever installed are Hookers and each install had to be done differently between manual and auto.
Old 02-25-2011, 03:43 PM
LT1559's Avatar
If you're doing this by yourself, get ready to curl up in the fetile position in the corner of your garage with a box of tissue from frustration...lol jk
Old 02-25-2011, 04:04 PM
95mysticta's Avatar
Dude... copper gaskets are the worst header gasket to use. They DO NOT seal worth **** and even if you do get them to seal you have seriously crank the bolts down. Not worth the extra cost for a peice of **** gasket get the felpro 1470s.
Old 02-25-2011, 04:28 PM
boostedlt1's Avatar
aren't the felpros 1460's? i just bought a set last week, i may be remembering wrong though
Old 03-03-2011, 02:17 PM
SoCalCal's Avatar
That passenger side did look suspect. Thats what stopped me from installing my headers my self.
Old 03-03-2011, 02:40 PM
carlos64030's Avatar
$300 is awfully freakin' cheap for a header install.
Old 05-26-2011, 06:14 PM
Okay so I bought the pacesetter longtubes with the EGR/AIR ports.. I wanted the race versions but came across a deal I couldnt refuse.. Any one think I'm going to have more issues because of the ports? I'm going for it in 2weeks..
Old 05-26-2011, 10:19 PM
02v8ta's Avatar
I just want to know which gaskets i should get for my pacesetter header install now? Links please?
Quick Reply: Lt1 longtube headers install?
