4l60e no lock up and staring off in 3rd
I just got my car back on the road after a head gasket failed and I am having some tranny issues.
94 Lt1 4L60E
It has been starting out in 3rd gear , but i can manually shift 1-2-3-4 , and also noticed the converter is not locking up.
This kinda sounds like limp mode but not sure. if it is what can i do to correct it?
The car can easily spin the tires and all clutches and band seems to be grabbing well. I hate to have to tear the tranny apart if its something like sensors or something.
Just a lil history , i had an off brand converter fail and lock up on me a few months back. I replaced it with a stocker, freshened up the tranny and replaced the pump since it was a little chewed up inside.
Hopefully this isnt a shot in the dark to diagnose but am hoping to get some useful thoughts on the culprit.
Thanks,
Mako
94 Lt1 4L60E
Thanks,
Mako
Internet Mechanic
Your having Stall Wall, thats for sure. I had the same in my 1994 383 z28, too high of a stall and the thing go into limp mode. If you shut off and restarted, it would go away but come back as soon as the PCM saw the RPM vs MPH diff.
But since you have a stock stall back in the car, it be odd that your having limp mode issues.
Just my 2 cents.
Just my 2 cents.
Ive only driven the car just since monday to work and back and still verifying what exactly its doing. I will try to scan it and see what the computer is saying..maybe just some faulty shift selenoids or something. It almost seems like it does right off the bat though just pulling out of the driveway.
Internet Mechanic
What the PCM is seeing for TPS voltage can have an effect as well. I think It cannot be more then 1.00, I have to go back to some old datamaster logs if I can find them but def look into that.
Also to mention my PCM never threw a DTC or SES light for stall wall, but it did for the TPS situation, and when putting it into gear would have a violent shift. This was all RPM based stuff.
I will check that TPS possibility..The car itself runs great besides this darn transmission.
Yeah trash is another concern. I cleaned out everything i could get to when i freshened it up,, but those lil pieces can hide anywhere.
I am going to have to run the codes tomorrow night. Gotta focus on the Wifes Chevelle build so i can have a garage back lol
