tube from head to head?
Old 03-03-2011, 09:31 AM
z28rob18's Avatar
Default tube from head to head?
I've noticed that there's a little tube that went from one head to the other on the back of the motor. what is it? what does it do? is it needed? and if so where can i get one? i remember seein a thread about this but don't remember the outcome and cant find the post.
Old 03-03-2011, 09:35 AM
93M6Formula's Avatar
It's part of the reverse coolant system that LT1's have and is vital to correct operation of the coolant system. You can get a new GM but they are spendy.
I know there is a few threads about how to make one from AN fittings and hose. just do a search. Its called the steam pipe usually.
qc97z's Avatar
You ABSOLUTELY need it. It's called the "steam tube" or "coolant crossover tube". It is necessary to relieve pockets of steam and coolant from the heads, the coolant flows from front to back on an LT1. It routes the coolant and steam back to the radiator.
You can replace it with barbed fittings and rubber hose, -AN fittings and connectors, pretty much anything you want that will take hot coolant for years to come.
I have NPT to -6AN fittings on the back of my heads, with -6AN push-lok hose to a -6AN tee, then up to the radiator. The -6 push-lok hose is the perfect size to connect right to the radiator with a hose clamp.
Old 03-03-2011, 09:51 AM
z28rob18's Avatar
that's what i thought it was. where does it connect to the radiator at? any pictures of one made of AN fittings
speedracer2536's Avatar
If you need one i have one forsale with the banjo bolts in great shape..
Old 03-03-2011, 09:57 AM
z28rob18's Avatar
^^^how much?
i just found this thread.
https://ls1tech.com/forums/lt1-lt4-m...-pictures.html
only thing i don't see is where it goes back to the radiator
Old 03-03-2011, 10:08 AM
I'd sell it for 45 plus shipping..
myltwon's Avatar
next time I break one I'm just gonna build my own. be careful with them then can bend, kink, and break easier than you'd expect if you're not careful.
Old 03-03-2011, 10:30 AM
quik95lt1's Avatar
heres how i did mine...........
-6an hose
-6an coupler
2 -6an to 3/8NPT 90* fittings
-6an T
one straight -6an hose end
one 90* -6an hose end....
Old 03-03-2011, 10:42 AM
myltwon's Avatar
-6an hose
-6an coupler
-6an T
how much did that run you?
Old 03-03-2011, 10:46 AM
quik95lt1's Avatar
guessing like 55ish with line.........good part is this stuff is bullet proof and its flexible!! lol
Old 03-03-2011, 10:52 AM
BigD383lt1's Avatar
-6an hose
-6an coupler
-6an T
How hard is it to change the cap and rotor in that thing? I would imagine there isn't much clearance!
Old 03-03-2011, 10:55 AM
quik95lt1's Avatar
nahh theres plenty of space this is a new setup so it hasn't even run yet with this dizzy.....but i measured it will work just fine
Old 03-03-2011, 12:13 PM
myltwon's Avatar
considering I paid like 80-100 for the gm piece that's a great deal
Old 03-03-2011, 12:23 PM
Im selling mine cause i went to the AN fittings and the pushlok hose.. It was like 75 or so before shipping from summit..
Old 03-04-2011, 12:56 PM
z28rob18's Avatar
ordered all the fittings thanks quik95. noone can tell me how it hooks up to the radiator though????
Old 03-04-2011, 01:00 PM
Z28Camaro30Ann's Avatar
dude, follow the line lmao. It hooks into the radiator JUST ABOVE the radiator hose on the left side...JUST BELOW your Radiator Cap. Not the one that runs to your overflow tank, bt the one just under that
Old 03-04-2011, 01:02 PM
z28rob18's Avatar
^^thanks. i dont have a line to follow thats y i didn't know
Old 03-04-2011, 01:05 PM
Here is a picture. My radiator shroud was off, but you should get the idea lol.
EDIT: WOW, that text was ALOT bigger when I made it lmao!
Old 03-04-2011, 01:23 PM
z28rob18's Avatar
ok perfect thanks for the pic and everything else guys.
Quick Reply: tube from head to head?
