MSD blaster coils=FAIL do not buy just go GM.
Old 03-03-2011, 09:58 AM
License2Ill's Avatar
Default MSD blaster coils=FAIL do not buy just go GM.
3 month old MSD blaster coil...failed last night....luckily a buddy had a spare stock coil. Probably about 15 yrs old. Worked great and got the car home.
Just goes to show I think truly the only quality parts are the original AC Delco products.
Fuggin amazin.
Old 03-03-2011, 10:06 AM
djjab57's Avatar
Mine didn't last to long either, The $15 AZ coil works great as well.
Old 03-03-2011, 10:35 AM
96blackz28's Avatar
I have had a MSD Blaster coil on my 96 Z with no problems for over 2 years and 15K+ miles.
But with that said, I have always been told to stick with Delco version.
Old 03-03-2011, 10:43 AM
Prorac1's Avatar
I have had the same MSD blaster coil on my 1997 SS for 9 years and 50,000 miles with no problems. I had one on my 1991 TBI truck for 5 years and 75,000 miles with no problems. I also had a Blaster 2 canister coil on my Plymouth for 10 years and before I replaced it with a 7AL2 set up, I ran a 9.64 on a 10 year old coil
Old 03-03-2011, 10:48 AM
shbox's Avatar
I had an MSD coil fail a long time ago, but they replaced it for free and that one has been going strong for 10+ years.
Old 03-03-2011, 10:49 AM
myltwon's Avatar
honestly if a stock part can do the job, stick with it no matter what the part. the aftermarket is much more hit or miss than OEM pieces.
Old 03-03-2011, 10:52 AM
Big Bad Bud's Avatar
8 year! 30K
Old 03-03-2011, 10:59 AM
93M6Formula's Avatar
3 years 15K on mine
Old 03-03-2011, 11:43 AM
sempire's Avatar
You'd figure someone would develop a good inexpensive after market solution by now.. This might as well be a BMW part..
Old 03-03-2011, 12:23 PM
iWon's Avatar
Would a SES code for low res ignition be related to the coil or most definitely the opti?
Old 03-03-2011, 12:39 PM
Gojira94's Avatar
Code 16 = Opti or low res signal degradation along the pigtail from opti to PCM.
Old 03-03-2011, 01:00 PM
ss.slp.ls1's Avatar
Why? The GM coil lasts for a long long time, and it is relatively cheap to replace.
Just like Gojira94 said, it's the opti.
Old 03-03-2011, 01:03 PM
GREGG 97Z's Avatar
Around 10 yrs on my MSD and no problems.
Old 03-03-2011, 01:16 PM
Incredible....you guys should try lotto...cuz I ran an MSD coil on a 75 Z28 also and it failed relatively quickly as well. This 1 is literally 3 months maybe 3000 miles.
I have ran the Crane Fireball for yrs before with it never dieing...I wanted to give MSD another try that's all.....but I dont think I'll be picking up any of their products anymore.
Old 03-03-2011, 01:59 PM
1961ba427's Avatar
I knew it was a low res code, but never heard the part about "along the pigtail from opti to PCM." That is kind of good news for me because I recently got this code. Cleared it and it didn't come back for a few thousand miles. Then one day I had a total no crank/no spark condition. A quick visual turned up that all 4 wires to my opti were chewed threw on the engine harness side by a rodent. (Along with the HVAC vac elbow.) I soldered the wires and it cranked right up running perfectly. Now 1,500 miles I have a missfire and no codes. I'm going to check plug wires, ICM, coil, etc this weekend.
Old 03-03-2011, 04:36 PM
Wicked94Z's Avatar
Originally Posted by DVS LT1
Hope I never have any problems with mine :S
I only have a few hundred miles so far. Since I was replacing everything else to do with the ignition this was the matching coil for the ignition box I already had.
Looks pretty cool - although you guys are right; its probably just added weight
Pictured here next to my old Crane fireball coil
The HVCII Blaster coils are a very nice coil for 99% of street cars, I've been running one for a few months now.
Old 03-03-2011, 05:39 PM
z_speedfreak's Avatar
one of the benefits of LS1tech is you could of learned that about them BEFORE you bought one
Old 03-03-2011, 06:26 PM
GMRL's Avatar
8 years 80k on my 97, no problems.
Old 03-03-2011, 06:46 PM
riceburnerZ28's Avatar
I brought one years ago and it failed last year with about 4k miles on it. I went and brought another one from here and its been working fine ever since. Although I do carry a backup coil ac delco coil just in case.
Old 03-03-2011, 06:52 PM
alexcoreas's Avatar
Msd blaster coil here 6 yrs and 30k miles
Quick Reply: MSD blaster coils=FAIL do not buy just go GM.
