car "surges" at WOT
car "surges" at WOT
i recently dropped the k-member and motor/trans out my car to change the head gasket. after reinstalling the k-member and engine/trans i got everything back in its place and now the car kinda jumps at WOT around 3500 RPM. i checked all my vacuum lines, wiring plugs, etc. any ideas? i just bought the car but from the one time i drove it before i dropped the motor i dont remember it surging like this.
any advice?
what to look for?
need more info let me know what u need!!
also idk if i have a SES light on the guy i bought it from pulled the bulb or it went out. (im sure it has one on though, gonna try to get a scan tool this weekend just wanted some input)
thx in advance!!!
any advice?
what to look for?
thx in advance!!!
also put new spark plugs and harmonic balencer in the car. sprayed around all vacuum lines and intake with parts cleaner to see if i had any leaks and didnt notice any!
man mine does the same thing! ever since a header install. Only at like 5500+ i don't think its a misfire right? Surging is the best way to describe it. I will post a video on it soon to see if yours is the same thing. It did it with old Opti as well. On my car, i fired the ignition wire leading from icm to coil then i just wraped them together and taped it. i am going to sauder them once i get my car back for the transmission shop this weekend. Did you ever have any ignition problems like that?
Normally, surging is caused by a lean condition. I'd tape a fuel pressure guage to the windshield and go mat it a few times. If the pressure drops off under load, you need either a pump or a filter.
i didnt have time to check the FP last night i was just going for a lil ride before i left for kentucky for work. when i get back i should have the rest of my parts to do my 6.0 swap but i would still like to resolve the problem for when i sell the LT1
