Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
MP 122HH Dyno Results Inside
Old 03-10-2011, 09:30 PM
CancerJCC's Avatar
Default MP 122HH Dyno Results Inside
Well I finally made the 2 hour journey to hit up the dyno before our nasty GA heat gets here. I am quite happy with the results and actually could have squeaked out a bit more if the dyno hadn't screwed up after my cool down period. (I had waited with the fan on for 10 minutes after this run but then the dyno messed up on the two runs after so I was heat soaked again when he got it fixed). No biggie, I have enough power to make things go boom anyhow!
The chart: (Started with 18* of timing but ended with 16.5* due to IAT's and also averaged 8 pounds of boost over the run)
The video:
http://www.youtube.com/watch?v=7HmeBuy5Fw0
Old 03-10-2011, 09:33 PM
itsslow98's Avatar
Great numbers...............but does it really portray an accurate rating if " had waited with the fan on for 10 minutes after this run but then the dyno messed up on the two runs after so I was heat soaked again when he got it fixed)."
How much of a decrease did you see with heat soak?
Old 03-10-2011, 09:37 PM
CancerJCC's Avatar
This WAS the second heat soaked run. I said I could have gotten more after the fan had been blowing cooling things off for the 3rd run (after 10 minute break) but his dyno messed up so again I had timing pulled throughout. Either way by the end of the run (dyno or highway) timing is getting pulled....
That make sense or only in my head? In other words THIS run was representative of taking off from a heat soaked car.
Old 03-10-2011, 09:40 PM
CancerJCC's Avatar
Oh and BTW no heat soak (Read timing being pulled) happened until 4779 RPM anyways so its not like the difference is huge with a loss of 1.5* the rest of the way to redline.
Old 03-10-2011, 09:47 PM
itsslow98's Avatar
Car should still pull like a **** even heat soaked with that kinda power though lol.
Old 03-10-2011, 09:54 PM
CancerJCC's Avatar
Haha yeah she does alright! BTW you got me thinking now that I might add some meth (very little while in boost only) to not be able to raise my timing advance but merely keep what I have commanded....
The part I hate about meth is that you have to refill it. But if I only use a bit of it maybe I could live with refills every couple months or so.
Old 03-10-2011, 10:05 PM
itsslow98's Avatar
My brother runs it on his GN, hes able to get 27-28lbs of boost on pump gas with meth. His alkycontrol kit uses a replacement windsjield washer fluid container so maybe a gallon or so. He doesnt fill it very often at all, you can even get like 5 gallon tanks that you could run in the spare tire well that you would fill maybe twice a year. Meth is THE ****!
Old 03-10-2011, 10:24 PM
CancerJCC's Avatar
No doubt it is a wonderful addition I am just not sure I am willing to become a meth addict! lol
Old 03-10-2011, 11:19 PM
ColeGraham's Avatar
damn...thats all i can say
Old 03-11-2011, 01:21 AM
CancerJCC's Avatar
Thanks man!
Old 03-11-2011, 01:42 AM
ColeGraham's Avatar
Thanks man!
i might be taking a trip to GA...dad lives north of Atlanta...you should can up, haha
Old 03-11-2011, 07:44 AM
raven154's Avatar
Nice numbers! Would have been nice to see tq over the 500 ft lbs line with the 122 but 420 ft lbs at 2k rpm aint nothing to bock at!
Old 03-11-2011, 08:57 AM
greddy91's Avatar
122 a direct swap for the 112?
Old 03-11-2011, 08:58 AM
ColeGraham's Avatar
yes it is
Old 03-11-2011, 09:34 AM
aroussos's Avatar
yes it is
So where can you find a CTS-V MP122 kit for the LS6?
Old 03-11-2011, 09:44 AM
ColeGraham's Avatar
they dont make a 122 anymore. what you can do it get a 112, and find a 122 housing and screws and mount it to the 112 base.
Old 03-11-2011, 09:49 AM
whisler151's Avatar
That's awesome!
Old 03-11-2011, 09:56 AM
CancerJCC's Avatar
I am always down for a meet up. Last year myself and another guy went to a car show and then strip club later that night with our wives! haha V owners are the coolest people I swear.
Thanks and yeah I think the LS6 is always HP biased but 5 and 5 would have looked much nicer!
Sort of. There a couple other little things you need to fug with but it isn't bad. A company called Mechtech are the ones who originally bolted the 122 on the 112 base. If you want specifics I would give them a buzz.
http://www.mechtech-ms.com/
Hmm appears as if their site is down, not sure if thats permanent though.
Old 03-11-2011, 11:12 AM
liqidvenom's Avatar
now this is a blower setup i can get behind...
where did you pick yours up from? is there any cts-v write-up on going from the 112 to the 122 unit? maybe a parts list to buy?
Old 03-11-2011, 12:10 PM
adanieljohnson1's Avatar
Think he got it from another member for $2500.00? I could be wrong but if not then that is one hell of a way to spend $2500.00!!!
Quick Reply: MP 122HH Dyno Results Inside
