Trickflow top end LS1 kit
Hey guys I was trying to do some research on the Trickflow top end LS1 kit. Summit racing sells this kit and I was curious to see if anyone out there has bought this? There are 3 different packages and far as I can see the cam specs are the only difference. I tried to do a search but couldnt really find this exact kit. If theres anyone out there running this, I would appreciate your input!
You could check with Vengeance. They sell a combo which includes the TFS heads, as cast or CNC'd version, your choice of Vengeance cam, and all the fixings like gaskets, pushrods, etc. They were just running a sale where you could get the 220 as cast heads with all the above for $2,500. One hell of a deal.
Purchasing AFR's was a big mistake! Mamo punched me in the face and stole my girlfriend! No but in all seriousness both heads will give you good results, I have Gen 1 AFR's and they made my 400 SBC bad-*** back in the day. TFS's will cost you more as I believe you must run a roller rocker with those heads, where as you can get away with stock with the AFR's. Just something to consider. Good luck.
