garage clutch swap
Old 03-25-2011, 12:38 PM
99 bad aSS's Avatar
Default garage clutch swap
Car desperatly needs a new clutch yet talked to the local shop and want 4 bills to install. Has anyone attempted doing this in your garage? I can't justify 400 bucks to put it in. I'd rather spend that on a shifter and new slave. I've done a couple of them before but always on a lift. Anybody have any tips or tricks that would help out please let me know.
Old 03-25-2011, 12:42 PM
Kleeborp the Moderator™
MeentSS02's Avatar
As long as you have a transmission jack that can roll under there, it really isn't an issue. It isn't as much fun as doing one on a lift, but it certainly can be done. My last clutch swap was done on my back in a one car apartment complex detached garage.
Old 03-25-2011, 12:52 PM
disc0monkey's Avatar
jack stands and get the car as high as possible. get a friend to help you. you can drop and lift the trans by hand with the help of a friend. im a 180lbs and got the trans out by myself wit no jack in an hour. Its a lot easier than i thought.
Old 03-25-2011, 01:37 PM
boss79z's Avatar
Yea. Agree with the ^^^^^^. It is easiest to get the bolts on the bellhousing (the 11 o clock and 1 o clock bolts) from inside the cab with some long extensions. You will use the hole in the floor for the shifter to turn the ratchet. Make sure to follow torque specs when installing new clutch, etc.
Old 03-25-2011, 01:45 PM
Nmbr1GMfan's Avatar
I think the biggest problem with this is if you were to let the trans hang weight down on the friction disc before the trans was in the pilot and on the dowels, you run the risk of bending/warping the disk leading to at the very least disengagement problems.
Old 03-25-2011, 03:00 PM
MeentSS02's Avatar
Exactly why you should use a transmission jack...it needs to be supported until it is fully bolted in place. I don't care how big/small you are...it gets tiring trying to hold that thing up on your back without a jack. This is especially important on a carbon clutch like the one I installed the last time...they can break very easily if the transmission isn't supported while being installed.
Old 03-25-2011, 04:45 PM
Blwn_by_Twins's Avatar
You can get a hands jack for under a bill too.
Trans jack....
Old 03-25-2011, 05:11 PM
therealcreeper's Avatar
5093th time I've posted this, but here's where I did my clutch:
..and with no trans jack
Old 03-25-2011, 05:45 PM
lexva_58's Avatar
^^^ lol
it can be done.. use a 20 in extenssion to reach the upper bolts... it is worth it if u dont have it
Old 03-25-2011, 06:26 PM
99 bad aSS's Avatar
Hey sounds great everybody, thanks for the input. Hopefully if you can do it in the snow i can get it done in 90 degree garage. Stocker made it 108k but it's time for her to go. well thanks again.
