you'll need to flycut the pistons for PtoV, but otherwise an LQ4 doesnt have enough compression for that cam to run right, unless you take a BIG cut out of those heads
I know, the cam was picked for the stroker. I was gonna use it for know in a lq4.
You are going to need big *** gears and stall for it in a stock cubed lq4. The lq4 is only 9.4:1 compression stock so if you do use it, it will be a dog of a motor.
I was spec'd around that same size cam for my 416 stroker from EPS.
