I can't figure this "offset (and or) backspacing" crap out...
Old 03-29-2011, 10:50 PM
andystaiger's Avatar
Default I can't figure this "offset (and or) backspacing" crap out...
I want 15in wheels on all 4 corners 7in wide on the front and 9in wide in the back...
What is the the backspacing I need for these wheels to fit (correctly) on a 2000 camaro?
Old 03-29-2011, 11:50 PM
67goatman455's Avatar
https://ls1tech.com/forums/wheels-ti...must-read.html
Old 03-30-2011, 01:26 AM
Cold Zero's Avatar
You cannot run 15x7 in the front ! ..
Old 03-30-2011, 09:13 AM
Why can't you?
And I've already looked at that thread before but it didn't give me exact measurements..
Old 03-30-2011, 12:32 PM
Why can't you run 15x7 in the front?
I'm still lost on this..
Old 03-30-2011, 03:35 PM
Tbird232ci's Avatar
They will not fit over the front brakes.
Old 03-30-2011, 06:40 PM
You can if you stud and spacer it, right?
Old 03-31-2011, 10:08 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
By the time you put in new studs and run a huge spacer it will look like **** and still not clear the calipers
