Tranny going out, T56 swap for auto?
Old 04-08-2011, 04:51 PM
CTSprojectR's Avatar
Default Tranny going out, T56 swap for auto?
Is it a little unreasonable to swap in a 6 speed tranny and replace the stock A4? My tranny has been making weird noises and i'm just starting to think about it before it happens so i can have a plan of attack. Thanks guys in advance.
Old 04-08-2011, 05:21 PM
ws6fitz's Avatar
Its not unreasonable. Search around the forum for a bit. There are write ups on this.
kk thanks
Old 04-08-2011, 05:33 PM
MR_M's Avatar
You should do it. My tranny is pretty much done for and i am in the process of swapping over to the t56 also. Check out the parts classifieds as some of the swap parts come by pretty cheap for the most part (pedals, crossmember, etc.) The tranny itself can be pretty pricey to some so be sure to shop around a good bit and make your best judgement. Good luck!
Old 04-08-2011, 06:00 PM
WSsick's Avatar
Many people have done it. As previously stated, T56s can be pricey so shop around before you make the dive on the first one you see.
Old 04-12-2011, 04:23 AM
Thanks guys, I appreciate it, any ballpark idea of what it would cost on average w/ all the parts not including labor? .. just a rough idea?
Old 04-12-2011, 07:46 AM
Rare96LT1Formula's Avatar
$2000ish. At least thats what my buddy paid when he converted.
Old 04-12-2011, 08:18 AM
02Z28ZO6's Avatar
$2-$3K depending on how much stuff is new or used. Your going to pay $1200-$1900 for a trans depending on if you get rebuilt or used. A good clutch kit is at least $400 and can cost over $1K for a good one. You would still need a pedal assembly, Clutch master, cross member, shifter, top half of the console, wire harness, flywheel and im sure there are some parts I am missing.
Old 04-12-2011, 10:08 AM
birdman283's Avatar
there's a write up on the swap, if you search a4 to m6 swap it'll have everything you need.
Old 04-13-2011, 05:26 AM
wav3form's Avatar
Why not get your A4 built up? Might be less money and it will be less hassle. I miss my M6 sometimes too but not that bad to switch.
Old 04-13-2011, 03:50 PM
camaro981289's Avatar
depends what you want to do. If you want a fun 6 speed car to drive around or maybe do autoX or some kind of corner track racing M6 is the way to go, If you want a consistant drag car then auto is the way to go. For the price of a stock t56 swap, u can get yourself a nice built auto thats reliable for DD and racing. I would choose auto but thats my opinion.
Good luck with which ever route you take man.
Old 04-14-2011, 09:18 AM
02Z28ZO6's Avatar
here you go, screaming good deal if you ask me.
https://ls1tech.com/forums/parts-cla...wheel-etc.html
Old 04-14-2011, 10:18 AM
T AM's Avatar
I personally know a couple people that have done the swap, and it is definitely possible. I'm swapping to M6 this summer. IMO, stalled A4's aren't much fun, unless your at WOT.
Old 04-14-2011, 10:28 AM
bstuby's Avatar
Damn.. that is a good deal. Now if only I had 2 grand haha
