rim ?'s
Old 04-09-2011, 01:18 PM
94ss06gxp's Avatar
Default rim ?'s
looking at the srt-8 charger rims, 20mm offset, not sure about backspace but would they fit? 20"x9"
Old 04-09-2011, 02:45 PM
Battle_Ravage's Avatar
Wow, I didn't know they were 5x115 also, I may look into their 17s. Will the guy let you test fit them?
Old 04-09-2011, 04:23 PM
LS1>girlfriend's Avatar
Might be a bit wide, see if he'll let you test fit them first.
Old 04-09-2011, 04:55 PM
94ss06gxp's Avatar
http://www.oewheelsllc.com/Wheels-fo...-p9360911.html
Old 04-09-2011, 05:07 PM
Oh, I thought you meant real SRT-8 Alcoas... 20x9s may be a little too big. But I guess you could run big spacers and roll the fender and/or flare them so the wheels don't look like they stick out so far.
Old 04-09-2011, 05:33 PM
94ss06gxp's Avatar
yeah, hmm i like the design of them and the price. guess ill have to find someone with an srt8 and see if they will let me test fit one
Old 04-09-2011, 07:50 PM
Can't find any close to that in an 18x8? Someone's bond to have something similar enough.
Old 04-10-2011, 03:45 AM
The Guz's Avatar
The bolt pattern is fine but the offset is what kills you. It is too low. The wheels would stick put past the fenders. As a rule of thumb, if a rim is 9 inches wide, dont go below 35 in offset. If its 8 in wide, dont go below 30. If its 7 in wide, dont go below 25. You will have issues if you plan to lower the car with that offset. Here is a pic on a 97-03 body.
Old 04-10-2011, 08:01 AM
94ss06gxp's Avatar
thanks for the info and the pics man!!!
Old 04-10-2011, 08:19 PM
2005gxp's Avatar
i have 18x9 with 35offset. they stick out in the back with a wide tire. 20mm offset would definately stick out.
