New lsx swap fox body manifold choice
i was able to use 2010 camaro exhaust manifolds and they fit great.. I figured if the stock manifolds fit then so will these
http://www.amazon.com/PaceSetter-70-.../dp/B003X6FUVW
headers for a LSX swap might only be 210 bucks now...
looks like it could be the AJE to me from what i see. Foxbody 4.8 can we get a couple more shots at different angels please, im curious where the steering shaft comes out of the firewall the clearence there and just atop of the steering shaft.
Yes i can shot some more pics tomorrow.. car is at the shop i work at. you want pics directly over the steering column where the shaft and column meet? I did a manual steering conversion on my fox while doing this lsx swap and i do need a different steering shaft... thinking of modifying the shaft thats for the Power steering
Yes please ,Im concerned about clearence arout the steering shaft where my Clutch master comes out. Also how the exit, more pics the better. FYI I just did the manual steering to and bought the Flaming river shaft, it has alot of adjustablity as far as length and is a very nicely built unit, though pricey I will admit. I love it that we have an option over the Kooks and Dynatech headers possibly.
going to remove the heat shield and i believe there will be plenty of room... we will se soon my manual steering shaft is on the way.. hopefully friday i will have it installed and i will know for sure if these manifolds will fit
its not hitting anything.. But its also not bolteed on to the column because the shaft is to short.. once i have the right shaft i will know for sure if if these will work.. being the shaft is to short makes me think fitment will only get better with the right steering shaft
they clear 100 PERCENT i took off the heat shield and it has about 1/2 inch of clearance.. these will work great for someone on a budget...
started a new project... cutting up a stock truck pan to make it work
Wish I could Tig, I would have done that for sure, My 120 Mig welder just doesnt seem to like aluminum
I cant tig ether i just know the right people.. I could have cut up stock 5.0L headers or even bought 351w headers... but with these i bolt them on and im done.. oh and they cost me nothing...
