swap runs! Odd problem now.
Well, finally got the LS swap running. I'm using a Speartech harness. 01 LS1 and harness.
For some reason the engine is only firing on cylinders 1, 7, 6, 4. But not a thing on 2, 3, 5, 8. It's like it's skipping every other cylinder in the firing order?? I'm baffled. Hoping it's something simple, but I can't seem to think for a second what'd cause that.
Ideas?
Ideas?
The way the harness is, everything will only plug into where it should. In order to plug something in wrong, you'd have to have the harness literally on backwards. What are the odds of this being caused by a cam or crank sensor only being plugged in partly? They're a real nightmare to get to with as close as the motor is to the firewall. Fairly certain they got plugged in all the way, but they're the only ones I can't readily see with my eyes.
I talked with speartech today and he assured me the harness was working correctly on his setup before it got shipped out, which I'd have to believe. So, I'm hoping it's something simple. Posted this to see if anyone else had encountered anything similar so I'd have a starting point in where to start looking.
Ya, were headed out to the shop tonight after I get off of work. I'm going to go through and double check all the connections. Unfortunately I can't start it that late at night behind the psychotic welfare lady who lives on the same lot that my shop is on, is off her meds and already verbally assaulted me the other morning after it started for 10 seconds. I almost felt like threatening her with not paying my taxes anymore so then she'd have to find someone else to pay for her 5 illegitimate children.
Well, figured it out. The PCM must have some bad drivers in it. Checked continuity in the Speartech harness and all was well, but no spark on 4 cylinders. Grabbed a pcm from a 01 WS6, uploaded my tune to it and it fired up today hitting on all 8 no problem.
ODD, considering the pcm and LS1 was working awesome before we yanked it for my car. I send the pcm and harness to Speartech, PCM is junk after hooking it up in my car after we get it back. Not impressed, but whatever. I'm just glad to have it all sorted it out and ready for driving and terrorizing the big block's again.
