new socket for front turn signal?
Old 04-19-2011, 10:49 AM
Davey G's Avatar
Default new socket for front turn signal?
Do any of you know where I can get a new 3 way socket for the front turn signal on my car? Rock auto has them for $45 but I wanted to see if I could get it any cheaper somewhere else.
Old 04-19-2011, 11:11 AM
BIG_MIKE2005's Avatar
Go to Autozone, part# 85881 they should be able $8 each, I'd suggest replacing both at the same time.
Old 04-20-2011, 01:46 AM
sjsingle1's Avatar
if you dont replace the bulbs with LEDs...........they will burn up again........ask me how i know
Old 04-20-2011, 01:57 AM
00MaroVSix's Avatar
i have a whole harness with good sockets. 10$ shipped for a pair? or you can find them at autozone for 6-10$ for one. just throwing it out there. pm me if interested.
Old 04-20-2011, 06:56 AM
It'll take a while before that happens, most of these socket failures happen from getting corroded. Easy way to ake them last longer is to drill a couple very small holes in the bottom of the housing for any moisture to drain out of so it wont pool in the socket.
Old 04-20-2011, 07:57 AM
sjsingle1's Avatar
my new socket burned up again in less than 6 months.......not to mention the new housings melted a little too
Old 04-20-2011, 08:10 AM
what bulb are you running? My stock pieces lasted until this past winter before corrosion took one out. And I do alot of early morning & night time driving so my lights get used alot. Havent had a melting issue ever though.
Old 04-20-2011, 08:47 AM
Davey G's Avatar
I have new led switchbacks that I went to put in the other night when I found that one of my sockets was fried. I just picked up two new sockets and two electronic flashers from autozone for $35! Thats cheaper than rock auto wanted for just one socket. Thanks for your help guys.
Old 04-20-2011, 06:03 PM
sjsingle1's Avatar
i ran the stock 3157 drl
Old 04-21-2011, 10:40 AM
Hmmm, weird its burning up so quick on you.
Old 04-21-2011, 12:01 PM
Save the manuals!
wssix99's Avatar
Here. Fix if for 50 cents!!!
https://ls1tech.com/forums/general-m...t-gaskets.html
https://ls1tech.com/forums/general-m...ng-insert.html
Delphi makes a special high temperature socket for these bulbs, but... they weren't used in our cars and I can't find a single place that has them in stock. Honestly, its far less expensive to replace the bad parts over and over again rather than getting the heavy duty housing as a special order. (The replacement sockets at the auto parts stores are the regular duty.)
The DRL bulbs are hot and they are going to char the sockets right away. No big deal. If things get bad, you can replace the insert and/or socket housing for pennies. AND - you don't need to splice anything in, keeping the whole setup good as new.
Quick Reply: new socket for front turn signal?
