so fuel pump went out today
Old 05-01-2011, 10:32 PM
King Nothing's Avatar
Default so fuel pump went out today
so what pump should i go with? a stock one will probably cost me more than $300 but how long will a aftermarket one last? close to 200K like my stock one did? the only mods i have are LT's and a tune and i don't plan on puttin any other gofast parts on the car
Old 05-02-2011, 07:33 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Depends on the level of modification on your car.
I have factory GM replacement pumps, entire new fuel senders or Racetronix performance replacement pump kits... all much cheaper than you stated above.
Please call me for more info & i'll get you the best part for your needs.
Old 05-02-2011, 07:39 PM
msydow's Avatar
ive installed a bunch of racetronix pumps. havent had any problems with them.
Old 05-03-2011, 06:39 PM
well damn lol before i read this i already ordered a walbro 255 through ws6store
Old 05-03-2011, 07:34 PM
jetlag's Avatar
From what I read on some threads... the Walbro 255 needs the bucket modified a little bit to fit?
I went with the Racetronix kit because it was well put together and went in very easy. It was harder to drop the tank than to install the pump and hotwire kit.
You should also get the Racetronix hotwire kit to give that pump the extra power it needs!
Old 05-04-2011, 06:23 AM
BIG_MIKE2005's Avatar
^^Yep. Walbro requires modification to the bucket & once thats done if you switch to a Racetronix later you'll need a new bucket. I just installed a Racetronix pump last night. I didnt use the hot wire kit but the pump still works great. Very simple install with step by step instructions. Took me about a hour cause I took my time. But I also already have a trap door so I can access my pump in less than 5 minutes.
Old 05-04-2011, 09:49 AM
bayer-z28's Avatar
I'm gonna have to mod a trap door on mine. I've got access to some good butyl tape caulking that will work Awesome to seal it back up.
Old 05-04-2011, 11:39 PM
LS1TECH Sponsor
Racetronix's Avatar
Please remove and properly clean your tank before installing a new HP pump.
http://www.aftermarketsuppliers.org/...f0jxnvabCRpK3L
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 05-06-2011, 07:42 AM
cindyA's Avatar
hi i have a racetronic fuel pump in my car and after about 3 days the car dies at low rpms andone day the pump just stoped workin for about 3 days. then just started to work again. i drove it for about 3 more days drove good then started to dies at low rpms again.. any ideas?
Old 05-06-2011, 09:58 AM
cindyA's Avatar
just drove it to town again and it died at a stop sighn
Old 05-06-2011, 03:18 PM
LS1TECH Sponsor
Racetronix's Avatar
Did you contact our tech support dept?
__________________
>WEB SITE<
Old 05-06-2011, 09:49 PM
cindyA's Avatar
no i didnt... how do i do that?
Old 05-06-2011, 09:58 PM
LS1TECH Sponsor
Racetronix's Avatar
support@racetronix.com
__________________
>WEB SITE<
Old 05-14-2011, 04:51 PM
Installed and the car runs great, actually acceleration feels better now...not sure if that's true or if I'm just stoked to have my car back up and running lol
Old 05-14-2011, 07:32 PM
SuperSam's Avatar
Good luck w/walbro pump. I had two fail on me...sux!!!
Old 05-14-2011, 09:39 PM
What are the mods you have and in how much time did they fail?
