Special Edition Vehicles - There is no such thing as a Firehawk?
hester09
05-10-2011, 08:52 AM
Ok so i have had my 01 firehawk formula for about 5 months now and hands down the first question i get is what in the world is a firehawk. How do yall explain it to people that dont know a ta from a camaro? Mine is a formula so that makes it even funner to try to explain.
sorry if this is in the wrong section i wasnt sure where to post it to.
1995blacktattop
05-10-2011, 09:28 AM
it's a tire :P
seriously though, just explain to them that it's a limited edition car made by SLP engineering.
Brangeta
05-10-2011, 12:32 PM
It's the model one step higher than Formula/TA
SSdreamz
05-10-2011, 01:29 PM
you explain it with a bitch slap to the back of their head...j/k
1995blacktattop
05-10-2011, 02:47 PM
that'd be the WS6 :P
JohnnyBs98WS6Rag
05-10-2011, 02:51 PM
Its got more rammer air than a WS6. :D
Seriously, just state that it's the top-of-the-line Firebird, upgraded by SLP, the same folks who upgraded Z28s to make the SS. Then watch their eyes light up: Ah HA!
picturethis
05-10-2011, 04:16 PM
normally people think that a Firehawk is way faster then a stock v8 fbody, I usually tell them if they dont know, a firehawk is a special order Firebird
99_LS1_WS6
05-10-2011, 11:02 PM
Here is my question, how does it have more ram air than a WS6 when it uses the stock lower air box and not even the raised lower air box. This is a question that I have wondered for a while,
Head Hunter
05-11-2011, 10:26 AM
I still remember being in Downtown Dallas when I was 14 or 15 and seeing a red Firehawk and being like "WTF?!?" - went home and immediately started reading up on it.
JohnnyBs98WS6Rag
05-12-2011, 09:06 AM
Uh, it doesn't. I was (trying) being funny.
In reality, the difference is probably too small to measure, but the WS6's larger/higher scoops and bigger lower airbox opening definately gives it the edge over any other LS1 intake setup.
98BlackTransAm
05-20-2011, 02:33 PM
I always just tell people it's a rare edition thats above a WS6. I like the fact that ppl are like "wtf is a firehawk" makes ppl wonder what it has done to it lol
babbage1109
05-20-2011, 02:35 PM
Trans am formula firehawk.....it's just a firebird lol. If they don't know already then they won't get it
cnd99hawk
05-20-2011, 07:19 PM
Haha exactly.. I just tell them it was a numbered car that has trim upgrades over the WS6. Plus if I pull into a cruise night here in Canada, people really think I have something special because Trans Am's are so few and far between, let along Hawks.
BCKNBLK
05-21-2011, 09:12 PM
ask them if they think a Yanko Camaro is a real car?
LT1_Hawk
05-22-2011, 02:49 AM
absolute easiest way to explain to people is to state that it is the SS of the firebird line but rarer. sometimes people will ask for more detail and then i will get into it but for most people and the commoner that answer will suffice.
Big Chuk
05-22-2011, 04:14 PM
The intake ports on a WS6 is raised with the hood. The intake ports on a Firehawk aren't raised therefore no need to raise the lower air box. As for which flows more air I am not sure of a test being done. Although both work on the same principle. Now you don't have to wonder anymore.
hawk584
05-24-2011, 08:45 AM
i just tell people it's a limited edition trans am... people dont' know any better any way and will believe anything anyone says.
ZYA_LTR
05-25-2011, 12:08 PM
It's not, but a Yenko Camaro is.
MrDude_1
05-25-2011, 12:24 PM
for what its worth... a simple aftermarket lid, the kind almost everyone has, flows more then the WS6 "ram air", or the firehawk intake.
the intakes are not special.. while we all know (or should know) the small diffs between a WS6, formula, and firehawk.. the reality is they're so similar one could consider them just body kit options... because the few minor changes between them are often the first things modified by the aftermarket anyway.
98BlackTransAm
05-25-2011, 02:28 PM
the biggest non-cosmetic difference with the firehawk is probably the bilstein suspension upgrade that many of them came with:
http://www.firehawk.net/images/lit/2001/content/bilstein.jpg
BILSTEIN ULTRA PERFORMANCE SUSPENSION SYSTEM
35mm front stabilizer bar
21mm rear stabilizer bar
Reinforced stabilizer bar brackets and special end-links
Bilstein shocks, recalibrated to SLP specs.
Progressive-rate front springs 223 to 448 lb.-per-inch
Progressive-rate rear springs 97 to 136 lb.-per-inch
Rear trailing arms with 1LE bushings
1LE panhard bar
Option Price: $999
MrDude_1
05-25-2011, 02:39 PM
1LE panhard bar
Option Price: $999
oh i agree... im not trying to put it down or anything.. and if you're going to keep the car stock, its a great setup.
my point was just that.. well look at what you have listed, then think about what most guys here do:
aftermarket LCAs\panhard have poly bushings... instead of the 1LE.
lowering springs replace the stockers
aftermarket shocks/struts replace the stockers.
while not often replaced by all, new poly bushing endlinks are less then $10 a set..
now if you were in autocross and wanted to stay in a stock class.. you wouldnt do that stuff.. but if you just look at the general mods people here do, it replaces most of that stuff.
im not snubbing the firehawk in anyway, i always loved it.. and the hood is just fuggin awesome. I was just commented on the "ram air" thing.
as for the OPs problem of explaining it... i can relate. seems like every vehicle I get has something about it that the average person doesnt "get" or believe..
dschmittie1
05-30-2011, 08:10 AM
I always explained it to People like a Roush Mustang. An out of hous complany that modify the cars before then get to the dealer. It is a little easier for people to relate too since Roush mustangs are a little more known than SLP and the Firehawk.
Oh and just an FYI not all SS cars went to SLP for modifications. SS hood went on in th factory. So only if they got some other upgrades from SLP did they go to SLP
97FormulaWS-6
06-06-2011, 09:40 AM
Side question -
I thought they stopped making Firehawks out of Formula's in '00? Or was that only WS6 cars?
Mad-Max
06-06-2011, 11:01 AM
I tell them that its 5 grand more then I should have paid and that even though there were only a few made don't waist your money on them. Unless your a collector, because SLP does not make replacment parts for these cars i.e badging, spoilers, rims,center caps. So go get a nice clean WS6 and that the extra cash you saved and mod it up.:chug:
hester09
06-06-2011, 12:32 PM
Just thought I would share this with yall the other day we were having our yard treated and the guy walks up to my dad and asks, "Isn't that firehawk the one that has the duel supercharged v6 in it from factory? Dad couldn't help but smile and say yep sure is. It amazes me how dumb people can be sometimes!
hawk584
06-06-2011, 02:01 PM
Firehawk body styles,
1992-1997: available in Formula body only
1999 - 2002: available in both Formula and Trans Am
2009: G8 ( :barf: )
