347,Tsunami Cam, tsp 2.5 ls6, fast 92 combo. any dyno guesses?
rebuilt my motor, has forged pistons, rod bolts, 6.0 crank. tsunami cam, TSP stage 2.5 ls6 heads milled to 59cc, Fast 92 combo ported to match the heads, SLP underdrive pulley, racetronix 37 lb/hr injectors, tsp 1 7/8 headers, through a slp dual dual setup for now. Ls7 clutch/flywheel, steel driveshaft, 12 bolt with 3.90 gears. 17 TT2s with 315's. I'm really hoping for 460... any ideas?
edit: should be dynoing it with in the next week
Congratulations
Those are GREAT results. If your compression is 11.1:1, then, calculations tell me that you have a -2cc dish pistons which is a good valve relief to reach a great compression.
Any video of the car?
