I Need Understanding
Old 05-20-2011, 09:18 AM
Str8BlkSS's Avatar
Default I Need Understanding
Ok i want to put and exhaust or switch out my mufflers but i dont understand what most of you guys mean by downpipes, cat or catlees. I not trying to be a pest but I want to sound good. I like the sounds of mustang and chargers, but i know i cant get those sounds. But I aslo heardn from a buddy of mine told me that i could switch out my converters and try to order some magnaflow converters, is that possible? and also what are some good mufflers?
Old 05-20-2011, 09:36 AM
TheJPGXP's Avatar
Downpipe is the pipe that connects the the exhaust manifold, and bends back. Really no need to replace the stock cat as it is high flow, unless you go catless. As far as mufflers, hit up YouTube, most run MagnaFlows. I'll be ordering Borla soon.
Old 05-20-2011, 10:00 AM
1CL3ANSUP3RSPORT's Avatar
Magnaflow FTW...
I would 3" catless and Res delete into 3" magnaflow's
Old 05-20-2011, 05:53 PM
nmp0098's Avatar
You won't sound exactly like a Mustang or Charger unless you swap in a Mod Motor or Hemi because the heads have a lot to do with sound, but you can still sound really nasty. Definately check out youtube. There are a ton of exhaust videos on there; I've got a couple up.
Edit: JP nailed it by the way. If you clarification, fire away.
Old 05-20-2011, 06:26 PM
Brian396's Avatar
I really like the sound of the muffler delete cars.
https://ls1tech.com/forums/ls4-perfo...y-exhaust.html
https://ls1tech.com/forums/ls4-perfo...aust-clip.html
Old 05-21-2011, 12:07 AM
RIPDEATH's Avatar
this is flowmaster 40's inside the car.
http://www.youtube.com/watch?v=E2BFbYSBGkw
this is 40's outside(sort of)
http://www.youtube.com/watch?v=xGgrpntTPMI
flowmaster 10's driving by.
http://www.youtube.com/watch?v=V4fGElOiKTk
this is 10's outside.
http://www.youtube.com/watch?v=d7TRrMYeKIo
this is 10's inside.
http://www.youtube.com/watch?v=0ausBl-yQO8
all have K&N intake and bigger piping from after the cat with different tips. Hope this gives you an idea of flowmasters style at least. Magnaflow also sounds good.
Old 05-23-2011, 04:42 AM
Panther427's Avatar
i think the 40's dont sound that much different than my open cut out with cat and res in.. i like the 10's
Old 05-23-2011, 04:43 AM
Panther427's Avatar
you can by aftermarket down pipes with or with out a cat.. the cat he sells is a magnaflow one. it sets codes in some cars.
Old 05-23-2011, 05:24 AM
Str8BlkSS's Avatar
Ok what does it mean when u guys say resonator deleted?
Old 05-23-2011, 09:08 AM
TheJPGXP's Avatar
The long muffler looking thing behind the cat. We cut it out and replace it with a normal piece of pipe.
Old 05-23-2011, 09:59 AM
Str8BlkSS's Avatar
May I ask what for or why is this done? what is the benefit? sorry I'm a newbie
Old 05-23-2011, 10:04 AM
TheJPGXP's Avatar
Mostly for sound. It's ok, we all started out that way. I'm 24 and still learning...
Old 05-23-2011, 04:04 PM
Panther427's Avatar
https://ls1tech.com/forums/ls4-perfo...aust-pics.html
2nd and 3rd pic show the cat and the newer section of pipe is where the resonator would have been.. As the name implies a resonator is tuned to for certain sound waves that would resonate and make most of the driving public unhappy to have in there car.
Old 05-25-2011, 01:45 PM
LS4:20's Avatar
I have a 3" catless downpipe with an open cutout.. Wanna talk loud? ***** sounds like a tractor on roids.. Lol.. Def needs headers or a cam, though, to get rid of that "hole-in-the-exhaust sound"..
Old 05-25-2011, 01:51 PM
TheJPGXP's Avatar
It's not THAT bad, I daily mine that way every once in a while.
^ Sounds like this.
http://youtube.com/watch?v=KjjFuw3Xom0
Old 05-25-2011, 08:59 PM
ls4door's Avatar
I love mine with just muffler deletes. A little droney but overall not to loud cruzing. I think mine would sound even better if I got rid of factory tips. Should have done that before.
Old 05-26-2011, 01:42 PM
i_ammetal's Avatar
I have Flowmaster 40's with a High Flow Down Pipe, and res delete. Nice solid tone, can be a bit raspy at higher on the powerband and the drone will **** your girlfriend off if your over 2100 RPM but thats what its all about anyways.
http://www.youtube.com/watch?v=GKJUExkYjSw
Old 05-28-2011, 02:02 PM
06silverss's Avatar
I had a Hemi before this and I really like how deep these engines sound! I had cutouts with Hiflow cats on my Hemi and it sounded wicked! I have a cutout on my SS and its not as wicked since it is stock exhaust all the way around but still love the deep sound!
Old 06-02-2011, 11:39 PM
rm08gxp's Avatar
i just did a mufler delete with larger oval tips after visually looking at stock tips which i was going to re-use. could not be more happy with sound. had a custom k&n at same time. will post youtube vids soon....i.m.o. its the only way to go , budget wise after esearching muffler option and magnaflows cat back sounds...
Old 06-02-2011, 11:42 PM
DavidGXP's Avatar
Getting rid of the muflers is a great way to shead some weight too!
