Ly6 Engine
Old 05-23-2011, 07:43 PM
EasternStryker's Avatar
Default Ly6 Engine
I have been looking at Ly6 engines lately and they are quite cheap used and make a good amount of power. I was thinking that it would be a good engine to use in a 1970 Camaro I plan on restoring does anyone know any details on this engine and what I would need to make about 475-525 rwhp with one. Any comments are welcome. P.S Must keep fuel injeted
(I was thinking fast 102mm intake,102mm throttle body, cam, ported heads, bigger injectors, something to get the compression ratio up, good tune,)
Intake & Throttle Body
http://www.fuelairspark.com/1/FS/Intake/Default.aspx
Cam
http://www.summitracing.com/parts/TFS-30602001/
Old 05-23-2011, 09:38 PM
BanditDave's Avatar
Pull the VVT stuff, replace the timing cover and cam gear with LS2 stuff, cam, headers, LS3 intake and basically you have an iron LS2 on 'roids. You already have the L92 heads which will make you a ton of power. Just match it with the appropriate cam and you have low 12s/high 11 sec car all day long. You don't even need the 102/102 fast stuff. If you get yourself the computers from a donor you can run the 90mm LS2 throttle body and get yourself an LS3 intake off here. Your power goals are easily achievable with factory stuff.
I would upgrade rod bolts as a precaution and possibly flycut the pistons if you are planning on running really high lift.
BTW, this is an LY6 in my '69 442 build:
Dave
Old 05-23-2011, 10:17 PM
hicksport's Avatar
Default my ly6
I've got an ly6 with Texas Speeds vvt-2 cam, LS3 intake and shorty 4th gen camaro headers and a single 3 inch exhaust, with a marginal tune it made 397hp 392 tq to the wheels. Im happy with it and it still gets 25 mpg!!
Old 05-24-2011, 02:09 PM
So I have also been looking and saw that a lq4 is the same engine but dosent have the l92 heads so do you think I should buy ly6 and remove vvt or just put l92 heads on lq4
and with either engine what mods should I be expecting to do to make about 475-550 at the wheels ?
Old 05-25-2011, 06:52 AM
futureuser's Avatar
I think your numbers could be acheived with an LS3, but are a little high (at the wheels) for an LY6, unless you're going to bump the compression too or run a power adder. The fast intake throttle body setup will help get you there, but are not worth that much money for the power. The LY6 could be a better blower motor because with it's 9.6:1 compression and that will definately get you your 550wrhp.
My opinion is based on second hand information.
Old 05-25-2011, 12:09 PM
BanditDave's Avatar
Regardless of RWHP, I have seen this motor in a heavy 3700+ llb '69 Chevelle running LOW 11s with an LY6 and was still very drivable.
Take it for what it is worth...it honestly depends on what your goals are and power numbers on a dyno don't really determine track performance as a whole.
Old 05-25-2011, 03:40 PM
tippy's Avatar
I'm also starting to poke around and look for an ly6 pullout, they can be had reasonable for sure.
Old 05-25-2011, 06:28 PM
ponjohn's Avatar
How many lbs of boost could you put to an LY6 with 9.6:1?
Old 05-25-2011, 09:18 PM
Yea I might run Boost kinda pricey !
I was looking at this
http://cgi.ebay.com/ebaymotors/Linge...Q5fAccessories
Old 06-06-2011, 06:39 PM
SlvrSierra4.8's Avatar
I have a 9k mile LY6 longblock for sale if you are interested....
Old 06-06-2011, 07:19 PM
Jimbo1367's Avatar
The LY6s have gone up in price the last yr- yr 1/2. Still a good deal concidering you have basically a LQ4 with L92 heads all ready on it.
Old 06-06-2011, 08:54 PM
venmousracer's Avatar
SlvrSierra4.8, pm me the price of that ly6.. Eddie
Old 06-06-2011, 10:39 PM
jamminj007's Avatar
Default camaro
[QUOTE=EasternStryker;14950609]I have been looking at Ly6 engines lately and they are quite cheap used and make a good amount of power. I was thinking that it would be a good engine to use in a 1970 Camaro I plan on restoring does anyone know any details on this engine and what I would need to make about 475-525 rwhp with one. Any comments are welcome. P.S Must keep fuel injeted
Cam
http://www.summitracing.com/parts/TFS-30602001/[/QUOTE
Works well in my 73
Quick Reply: Ly6 Engine
