Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Camaro and Firebird: How to Install Lowering Springs
Step by step instructions for do-it-yourself repairs
lowering spring install, $500. is this accurate?
got a quote today to install lowering springs on an 02 ss. i was told 500 for the install and 200 for alingment. is this waht i should be paying?
that does not include the price of the springs
I'd say the install price and alignment price are pretty high. The rear springs are stupidly easy to do and the fronts don't take much time at all. I don't know what your situation is, but I would at the very least consider doing it yourself. It's a simple install and when you do have money together to buy shocks you won't have to pay again to have that installed.
The alignment, most shops charge extra for modified cars but normally i've seen prices right around $100 to align a lowered car.
that seems really high. I paid 575 for a shock and spring install along with bumpstops and new strut mounts AND an alignment. I provided all the parts except the strut mounts. Labor was only $59/hr and they said it took about 5 hours. This was at a specialty suspension shop though.
That's high. Rears you can do in 30-60 minutes. Fronts are a little tougher, but don't take long to do. I had a mechanic I know do them on the side for $75 for just the front. Alignment was $50 for me at a GM dealership
Like the others said, around the midwest its usually $60 to get an alignment on a vehicle. Rear springs are ridiculously easy. Use a jack and lift the car up by the rear differential, put two jackstands on the subframe, and let the rear end drop down...you can usually pull them out by hand, shocks are 2 bolts each to take out in the back.
use LS1Howto.com and do the install yourself, then just go somewhere and get an alignment once you're done. i pay $40 for a front end alignment at a local shop.
Front Spring/Shock swap
Rear Sprint/Shock swap
just to add one thing on the front swap that they don't include in that article, be sure that once you take the 2 Torx bolts out from under the brake booster, in order to prevent it from being a major pain in the *** in the event you ever have to do it again, swap them out with 2 of the standard hex-head bolts from the passenger's side....they're the same length and thread, but putting the Torx bolts on the passenger's side will make it much easier to remove again next time, and you may not even need to loosen the brake booster on the driver's side, depending on if you have wrenches that will slide under it without binding.
