Pacesetters installed!
Well finally got the pacesetter LTs and pacesetter ORY in last night. It wasnt as bad as i thought i was going to be. I think the hardest part was getting all the old stuff off. I actually think the fitment of these pacesetters was pretty darn good. They tuck up there really nice. Last night i didnt grind on the K-member but as i was coming home i felt a vibration in the steering so i knew thats what it was. So this morning i checked and sure enough i could see the header up against the k-member. I did a little grinding and no more rumbing or vibration. All in all the install went smooth and the fitment of these headers and ORY is very good. I would recommned these to anyone.
Congrats on the install!
I just did my install with some buddies this past Saturday... got the Pacesetters, Rumbler Catback, and Harlan Shift Light all put on. Gotta say I agree with you... the fitment of the actual headers are pretty good. Went on with little or no trouble... I notched the k-member as well to give it clearance, as it didn't seem to be touching until all the header bolts were tightened.
Did you use the Pacesetter Y-pipe? I did, and I don't seem to have many of the same kind of problems other people have had with it...
Originally Posted by ShadowLightCSU
When the headers were on, did you pry the header out of the way or loosen it up to grind it?
Daniels y-pipe fit pretty well, he has the stock catback (not adjustable), y is a little longer than the stock piece so we had to move the stock catback back a little. Overall i was impressed with the fitment and ease of install. About like my Qtp's except for the k-member problem.
No leaks so far. The welds werent the best of the best but they werent bad either. I am not sure what you mean by slag? But i think these headers are worth every penny of $374.99. Before i got them i was expecting for the quailty to be down but when i finally got them i was impressed.
Used band clamps all the way around for the entire exhaust (headers & catback) and no leaks so far... I've checked it a couple of times since the install and everything's great.
