Exhaust won't stay put
I recently did H/C/I and exhaust. I have ARH headers with catted Y and magnaflow cannon tip catback. I am using band clamps for all connections,this style http://www.jegs.com/i/Dynomax/289/36438/10002/-1?CT=999 and I cant get everything to stay put. The two tailpipes are moving the most and the intermediate wants to slide rearward off they-pipe. I can get the tail pipes lined up the best I can (about 1/4 to half inch from bumper) but after a short drive around they have shifted up and are touching the bumper
Do I need better clamps or are they just not tight enough? I have the clamps tightened down to 35 ft/lb's how tight can I go?
I have the magnaflow cannon tip exhaust as well. I had the same problem with the tips no matter how tight I got the band clamps. Only thing that worked for me was takin it to a shop and having them put a little spot weld on the pipe. Stays put and if I ever need to remove them all i need to do is grind the little spot off.
I would hate to weld it up, any other clamping method I could try?
Wouldn't welding a bracket on the tips damage their finish? Have any pics of the borla setup you are referring too.
My magnaflow tips do the same thing. And I just have the cat back only on right now and the tips love to come up I can just push them back down. I take a ride they are back up , when I get my longtubes put on next month Im having them cut the Gaint tips off and. Just having it tucked up For a much cleaner look. Also the over the axle pipe likes to come loose and rub on my drive Shaft and make a clunking noise >.<
Thanks for the pic Vin, makes sense now. If i cant sort the problem myself and end up going to an exhaust shop I might have them do that!
I was wondering about those kind of clamps , the look like they would have a lot more clamping power. Where did you get them and how wide would you say they are?
