Pontiac GTO 2004-2006 The Modern Goat
05 gto paint help
Old 06-07-2011, 08:32 AM
rockhammer52's Avatar
Default 05 gto paint help
i recently bought a new gto. its black and i was wanting to paint the gto plastic part underneath the bumper. ive never done paintwork before and was wanting to try it out. any help on what the process should be would be greatly appreciated.
Old 06-07-2011, 11:56 AM
mark21742's Avatar
Because of its location id just use some formula 2001 on it to shine it...if you put any paint down there as soon as you touch a curb it will start peeling and look worse than it does now
Old 06-07-2011, 01:12 PM
id really like to have it painted flat black. i think it would look good. i think i have to get paint with flex coat in it. do i need to sand it first?
Old 06-07-2011, 02:26 PM
mark21742's Avatar
It's been so long since I had that peice I can't remember if its textured or not....if its smooth is sand it with 400 grit wet paper, if its textured I'd use fine scotch brite.
Then spray on some adhesion promoter
Then use a paint like (rattle can) Fusor from Krylon that is made just for plastic...spray it as thin as you can because the thicker the paint is the easier it will chip and flake
Old 06-07-2011, 03:15 PM
cool.its smooth plastic.it shouldn't be too hard.thanks fire the help.I'll post before and after
Old 06-07-2011, 08:37 PM
I should have specified.im talking about the rear bumper where it says gto
Old 06-07-2011, 09:15 PM
mark21742's Avatar
Oh ok lol I wad thinking of the little flap under the front bumper lol
Old 06-07-2011, 09:17 PM
mark21742's Avatar
Yup scuffle it good, shoot some adhesive promoter on it and blast away
Old 06-08-2011, 09:29 AM
thanks for the help. we'll see how it goes
Old 06-08-2011, 12:34 PM
redtan's Avatar
Don't even need to scuff it, it's plastic. That's why people use adhesion promoter because you can't scuff plastic.
I used that stuff with a can of flat black bumper coating and it looks great and has held up so far.
Old 06-13-2011, 12:01 PM
lakingsrock21's Avatar
i sprayed mine two years go, took it off, masked it, cleaned it and used some krylon plastic paint then clear coat. steal looks good, starting to show red since the rocks hitting it but im doing it again lol
Old 06-13-2011, 04:44 PM
Thanks for the help.ask done and its back on the car.looks really good.will post later tonight
Old 06-13-2011, 07:18 PM
after the flat black paint job. took about 2.5 hours total. i love it.
Attached Thumbnails 05 gto paint help-251772_588859081492_197103617_32525748_6663494_n.jpg   05 gto paint help-259985_588859166322_197103617_32525750_4491044_n.jpg
Old 06-13-2011, 07:43 PM
ULTIMATEORANGESS's Avatar
i had mine painted flat black. it came out nice.
