Nitrous switch wiring
Old 06-26-2011, 01:18 AM
mean98camz28's Avatar
Default Nitrous switch wiring
I have went threw alot everything in the notes about This and no one has answered it. Can you guys helP me out please.
Where is the right choice to put my switch 12 volt key source and I have them wired together in a pair meaning I y them together
Old 06-26-2011, 01:30 AM
bernarlitt's Avatar
The guy that installed mine ran my 12 v switched to a fuse in the fuse box. Dont know if its the safest or best place but its been flawless for almost 2 years now for me. Hope this helps!!
(If its a bad place I hope someone else chimes in.)
Old 06-26-2011, 08:23 PM
SS1875's Avatar
Hope this helps you out. Very easy to do. I used the the fuse for the gauges by the way. Also if going this route, the panel cover will stick out just a bit at the top...I used some black electrical tape to help hold it...can't even tell when the door is closed.
https://ls1tech.com/forums/album.php...ictureid=71920
Old 06-26-2011, 08:50 PM
Yeah that would work but wat about a power source for the acc post by and fuse boxes under the hood with a 30 amp fuse tied in with it bc it will be bring power the wot switch and the purge together and both are a three porg switch
Old 06-26-2011, 10:25 PM
SS1875's Avatar
I may be wrong but isn't that post a constant power not switched 12 Volt source?? Not sure what to tell you on the fuses under the hood...I think I looked there and chose my path instead. Guess it depends on how you have things run under the hood as to the best fit in your application.
Old 06-26-2011, 10:31 PM
Nitro Dave's Nitrous Outlet's Avatar
Personally I pull the keyed 12 volt from the back of the fuse box area. I feed the relay power a direct feed from the battery. BUT we install a small fuse box in all our installs. The heater, purge, system, dedicated and all have fuses. So technically we have a positive feed from the battery to fuse box and then to components.
The fuse blocks we use are in this link.
http://www.nitrousoutlet.com/catalog...26&section=122
Old 06-26-2011, 11:37 PM
SS1875's Avatar
Graham, that's how I did mine, battery for direct power to the relay and 12 volt keyed from interior fuse panel to the switch plate.
Should I put a fused link into the power wire from the batt to the relay??
Old 06-27-2011, 12:16 AM
Ok which fuse is the best one to pull from and what about tapping into the asr pink wire how is this one because I have heard of people doing this too. I going to try to finish the wiring on it tomorrow
Old 06-28-2011, 12:32 PM
SS1875's Avatar
I used the gauge fuse....works fine. I thought about the ASR as well but decided the fuse panel was a better choice for me. I don't see any problem doing it either way...just less time maybe.
Old 06-28-2011, 01:29 PM
Graham@NitrousOutlet
Guest
Posts: n/a
That was the boss not me
Never hurts for a little extra safety.
Old 06-28-2011, 03:30 PM
camscam02's Avatar
We use a wire tap on the foglight or tcs power wire. Works perfectly. Relay power directly to battery with a fuse
Old 06-28-2011, 09:51 PM
minytrker's Avatar
wire taps
Old 06-28-2011, 10:55 PM
SS1875's Avatar
Guess I should have put a fused link in the power wire when I thought about it..oh well easy to do.
Old 06-28-2011, 10:56 PM
SS1875's Avatar
OOPS!! My bad
Old 06-28-2011, 11:03 PM
camscam02's Avatar
Originally Posted by minytrker
wire taps
hahaha, I knew someone would catch that.
Quick Reply: Nitrous switch wiring
