LS4 Performance - hud stopped working
2005gxp
06-27-2011, 05:01 PM
the hud on my 05 gxp stopped working on my way home from work today,is there a fuse linked to this or is the bulb the only thing that could be wrong?
2005gxp
06-27-2011, 05:07 PM
just had a look at it and the spring is broken, how do i fix this?
GXP25
06-27-2011, 06:13 PM
Do a search on here or GPONA or Grandprixforums.
2005gxp
06-27-2011, 06:48 PM
working on getting it out now, i took out the 2 obvious 10mm bolts but there seens to be something else keeping it in there any idea what?
Mgpeagle
06-27-2011, 07:42 PM
You also need to remove the speedometer too. There is a screw behind it (iirc) that needs to come out. It holds the actual HUD in. My biggest challenge was getting the actual HUD cover out. The one that runs the lenghth of the dash. Be careful because it can crack very easily.
-Mike
2005gxp
06-27-2011, 07:59 PM
out fixed and back in bout 20 mins ago. stupid screw behind the cluster
GXP25
06-27-2011, 08:03 PM
-Mike
Yeah, that damn bolt behind the IP cluster. And yes, that trim does tend to crack (mine is cracked as I type).
2005gxp
06-28-2011, 06:43 AM
i didnt crack mine:D
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
