low traction light?
Old 06-28-2011, 08:37 PM
alexcoreas's Avatar
Default low traction light?
This has only happened twice both times have been after a carwash were my low traction light turns on when I'm trying to brake and my car brake pedal goes all the way down I have to let off and pump them again to brake wtf is this. I tried searching but maybe I'm wording the search wrong
Old 06-28-2011, 08:46 PM
alexcoreas's Avatar
Found some info but not really helpful. Ill just delete ABS hope it works either way my ABS inop light is always on
Old 06-28-2011, 10:03 PM
Gojira94's Avatar
Wet ABS sensor getting fooled into thinking a wheel or wheels are turning slower than the others. ABS pump & modulator act to reduce line pressure to a wheel or wheels that aren't really locking. Pedal goes way down, low traction light comes on.
Year of car? 3 channel or 4 channel rear? Seen what condition the wheel speed sensors are in lately? (rust / crud buildup + water adversely affects the wheel speed sensor signal).
Old 06-29-2011, 06:42 AM
DAVE00's Avatar
Check your wheel speed sensors.
Front Wheels - 2 plugs one each on the back of the hub
Rear - 3 Channel is on top of the rear diff
4 Channel is on each rear wheel.
Same thing happened to me and it turned out to be a bad front wheel speed sensor - bulit into the hub so you have to replace the whole hub.
Old 06-29-2011, 02:24 PM
alexcoreas's Avatar
Well its a 95 z28 m6 I got the rear off of a 97 z28 A4. Ill check it right now it'll be a min before I get back to responding.
Old 06-29-2011, 02:25 PM
DAVE00's Avatar
The 95' runs the 3 channel ABS and the 97' runs the 4 channel and that could be your problem. Did you modify the diff to run the 3 channel?
Old 06-29-2011, 02:56 PM
Fazz73jr's Avatar
^ My 95' has the stock 4ch rear? Are you sure about that?
Old 06-29-2011, 03:12 PM
DAVE00's Avatar
Only if you have TC (traction control) installed will you have the 4 channel and in 95' it was not that common.
Old 06-29-2011, 03:39 PM
alexcoreas's Avatar
Yea I think that's my problem it has traction control and my car doesn't. I'm gonna lift it and pull the rear out.
Old 06-29-2011, 06:56 PM
nascarnate326's Avatar
My ABS and Traction are both non functional. Happened after my headers were installed.
Quick Reply: low traction light?
