which shifter????
which shifter????
took my old nam. buddy out for a virgin ride,long story short, i missed 3rd twice at 85mph finally found it and took off . new rebuild on 50k tranny ,new carbon fiber,blocker rings, steel 3/4 fork etc.. shifter sloppy, made my own stalk direct bolt on. got rid of that rubber mounted black thing. what do you guys suggest? it has the stock hurst shifter now.i dont want to miss any more it makes me feel like a dumbass!! i didn't over rev. but next time i might not be so lucky. need short throw,positive engagement. thanks in advance...
A buddy of mine misses gears when he over heats his clutch. For ex. doing a small pull in a high gear will over heat the clutch. He has the LS7 clutch. What clutch are u running??
I'm running monster stage 2 with tick adjustable master i dont ripp it too hard just up enterance ramps. I deffinitly merge with traffic the shifter was the only thing i didn't exchange when i did my build and it is sloppy!! ordered an mgw today,2 week back order but, true craftsmanship takes time.On alighter side all you patriots celebrate our countries freedom this weekend and thank the veterans for making it possible!!
You go Hurst and it's going to be easy to shift but not very accurate when slamming gears. Pro 5.0 or probably MGW and you can slam the **** out of it and you'll hit the right gear every time.
